It is currently Fri Oct 02, 2026 5:59 pm
Post Posted: Sun Sep 20, 2009 12:01 am
as the topic sais.. what do people use and what do people find to be the best in the transfer case
Post Posted: Sun Sep 20, 2009 12:23 am
Did u put the 6.5 gears in yourself. I need to do mine soon. Any tips?
I was gonna run the standard castrol 80/90.
Post Posted: Sun Sep 20, 2009 12:45 am
Standard recommended transfer oil is the go. Castrol VMX80...
Post Posted: Sun Sep 20, 2009 1:06 am
I run heavy weight Redline shockproof in mine.
IMHO normal 80/90W is fine though.
Post Posted: Sun Sep 20, 2009 1:07 am
i have vmx80 with about 200ml of moreys.
Post Posted: Sun Sep 20, 2009 1:09 am
$15-$20 for Castrol or $100-$150+ for Redline. 8O
Post Posted: Sun Sep 20, 2009 1:20 am
Hey hutch
no I didn't install them myself.. Got them already in a box. So I have no idea.. They are suppose to be fairly easy to install..
Cheers guys for the response.. I just wasn't sure if they run some special oil
in them..
Moreys?? Is it similar to gearbox treatment??
Post Posted: Sun Sep 20, 2009 1:22 am
moreys is just an additive, because it is so hot here i recon gear oil needs a bit of help.
Post Posted: Sun Sep 20, 2009 1:53 am
i use 80% moreys 20% 90w gear oil
Vehicle: 1999 Jimny
Post Posted: Sun Sep 20, 2009 12:58 pm
Simple......... Penrite.
Post Posted: Sun Sep 20, 2009 1:01 pm
Is that to keep the seals soft?
Post Posted: Sun Sep 20, 2009 1:20 pm
i don't think it affects the seals, it is a oil stabiliser.
Post Posted: Sun Sep 20, 2009 3:06 pm
will i put the transfer into the car.. i ended using a 80/90 and some moreys..
am amazed at how low low range now is... it blew me away... the best mod by far.. and got them for a steel..
$300 and some time to sought out why his car wouldnt start after an engine conversion (took me 5 minutes) blown fuse and fusible link.. hehehe
Post Posted: Sun Sep 20, 2009 3:25 pm
i recon gearing is the most important mod that can be done to a sierra.
Users browsing this forum: Google [Bot] and 149 guests
