| Author |
Message |
89_tintop
Joined: Fri Aug 07, 2009 11:30 pm Posts: 3159 Location: gold coast
 Posted: Sun Sep 20, 2009 12:01 am |
as the topic sais.. what do people use and what do people find to be the best in the transfer case
hutch
Joined: Sun Nov 30, 2008 10:30 pm Posts: 1213 Location: SW Bris
 Posted: Sun Sep 20, 2009 12:23 am |
Did u put the 6.5 gears in yourself. I need to do mine soon. Any tips?
I was gonna run the standard castrol 80/90.
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Sun Sep 20, 2009 12:45 am |
Standard recommended transfer oil is the go. Castrol VMX80...
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13011 Location: Melbourne
 Posted: Sun Sep 20, 2009 1:06 am |
I run heavy weight Redline shockproof in mine.
IMHO normal 80/90W is fine though.
shep
Joined: Thu Mar 29, 2007 11:30 pm Posts: 14498 Location: Here there everywhere
 Posted: Sun Sep 20, 2009 1:07 am |
i have vmx80 with about 200ml of moreys.
want33s
 Posted: Sun Sep 20, 2009 1:09 am |
$15-$20 for Castrol or $100-$150+ for Redline.
89_tintop
 Posted: Sun Sep 20, 2009 1:20 am |
Hey hutch
no I didn't install them myself.. Got them already in a box. So I have no idea.. They are suppose to be fairly easy to install..
Cheers guys for the response.. I just wasn't sure if they run some special oil
in them..
Moreys?? Is it similar to gearbox treatment??
shep
 Posted: Sun Sep 20, 2009 1:22 am |
moreys is just an additive, because it is so hot here i recon gear oil needs a bit of help.
ajsr
Joined: Sun Dec 28, 2008 10:30 pm Posts: 3712 Location: melb
 Posted: Sun Sep 20, 2009 1:53 am |
i use 80% moreys 20% 90w gear oil
twitchy
Joined: Fri Jul 25, 2008 11:30 pm Posts: 1086 Location: Lightning Ridge
Vehicle: 1999 Jimny
 Posted: Sun Sep 20, 2009 12:58 pm |
hutch
 Posted: Sun Sep 20, 2009 1:01 pm |
shep wrote: with about 200ml of moreys.
Is that to keep the seals soft?
shep
 Posted: Sun Sep 20, 2009 1:20 pm |
i don't think it affects the seals, it is a oil stabiliser.
89_tintop
 Posted: Sun Sep 20, 2009 3:06 pm |
will i put the transfer into the car.. i ended using a 80/90 and some moreys..
am amazed at how low low range now is... it blew me away... the best mod by far.. and got them for a steel..
$300 and some time to sought out why his car wouldnt start after an engine conversion (took me 5 minutes) blown fuse and fusible link.. hehehe
shep
 Posted: Sun Sep 20, 2009 3:25 pm |
i recon gearing is the most important mod that can be done to a sierra.
