It is currently Sat Sep 26, 2026 10:11 am
Post Posted: Wed Nov 04, 2009 5:52 pm
Guys, having an issue a with my 04 Jimny speedo.
It fluctuates at speeds, ie when I speed up to 60 it would hit 60 then flick up to 65 bobble and come back down and when I accelerate again the same thing happens.
You can't keep on a constant speed because it fluctuates up and down.
Any Idea whats causing it and what I can do to fix it?
Post Posted: Wed Nov 04, 2009 6:20 pm
Are Jimny's cable speedo?
The cable will prob be sticky inside the guide outer....
Possible remedys:
Buy a new one to fix.
Lube whole inner cable with wd40. So take it out, lube up, put back in etc
Make sure there is no tight bends in the cable on the car so if you have moved it to work on other parts etc, move it back to original placing.
If electric..
Make sure plugs/inner terminals are all clean and connected to gearbox/transfer and through car etc.
Make sure arrow isnt sticking on speedo(and for cable)
Post Posted: Wed Nov 04, 2009 6:35 pm
they are electric.
I noticed it after I had my UHF installed.
But now that I'm thinking about the sensors, I do have a leak somewhere in the transfer case output seal. but I dunno if that would do it
Post Posted: Wed Nov 04, 2009 10:57 pm
i'd be looking at that. maybe they connested inti that or an eareth that runs off it. dirt etc will not affect the sensor in the t/case.
Post Posted: Thu Nov 05, 2009 12:12 pm
Bit early to be on the Bundys?
Post Posted: Thu Nov 05, 2009 12:21 pm
joeblow wrote:
i'd be looking at that. maybe they connected in to that(your speedo in put) or an earth that runs off it. dirt etc will not affect the sensor in the t/case.
Stop typing with your broken finger... :wink:
Fixed :!:
Post Posted: Thu Nov 05, 2009 12:24 pm
Or were you just trying to join in with some of the other dislecsic's on here :lol:
Users browsing this forum: Google [Bot] and 62 guests
