It fluctuates at speeds, ie when I speed up to 60 it would hit 60 then flick up to 65 bobble and come back down and when I accelerate again the same thing happens.
You can't keep on a constant speed because it fluctuates up and down.
Any Idea whats causing it and what I can do to fix it?
Joined: Sun May 04, 2008 11:30 pm Posts: 9717 Location: NSW
Posted: Wed Nov 04, 2009 6:20 pm
Are Jimny's cable speedo?
The cable will prob be sticky inside the guide outer....
Possible remedys:
Buy a new one to fix.
Lube whole inner cable with wd40. So take it out, lube up, put back in etc
Make sure there is no tight bends in the cable on the car so if you have moved it to work on other parts etc, move it back to original placing.
If electric..
Make sure plugs/inner terminals are all clean and connected to gearbox/transfer and through car etc.
Make sure arrow isnt sticking on speedo(and for cable)
i'd be looking at that. maybe they connected in to that(your speedo in put) or an earth that runs off it. dirt etc will not affect the sensor in the t/case.
Users browsing this forum: Google [Bot] and 98 guests
