It is currently Fri Nov 13, 2026 11:58 pm
Post Posted: Wed Dec 02, 2009 2:20 am
Hi all , im looking at doin a 2 inch bodylift to my 92 WT , should i do this b4 or after a suspenion lift ?? wanna run 31x10.5xr15's also does any one have any tips on the lift do's and dont's any replies appreciated
Post Posted: Wed Dec 02, 2009 3:11 am
Beat advise I can offer is avoid body lifts as long as you can I run 31x10.5 with no b/l and I get very little scrubbing
I do run bumpstop spacers and my front guards have been massaged though which helps
Post Posted: Wed Dec 02, 2009 4:19 am
The body lift is $210, a suspension lift is about $600+. You'll want both eventually anyways so do as your budget allows. Can you fit 31's without a BL, yes, if you intend to bash the yell out of wheel arches with a hammer. if you go the BL you have to do the seams anyway but not the entire guard and firewall.
Post Posted: Wed Dec 02, 2009 11:27 am
here is a 50mm spring lift and a stretched tight brake line.
Post Posted: Wed Dec 02, 2009 2:30 pm
I have never had a problem with tight brake lines :? Maybe they aren't factory ones?? I run the Commo/Hilux shock setup with extended bumpstops in the front and there is still plenty of slack in the line at full extension of the shock.
Post Posted: Wed Dec 02, 2009 2:41 pm
In answer to the original q, do both body and suspension lifts. Extend bumpstops and run long shocks to get the most out of the springs. I did body lift first then suspension but it doesn't really matter which way you do it.
Post Posted: Wed Dec 02, 2009 4:14 pm
Nice cleanup :wink:
Post Posted: Wed Dec 02, 2009 5:53 pm
that is HD OME springs with commo shocks. i was surprised just how tight they got.
Post Posted: Wed Dec 02, 2009 11:49 pm
whats a good shock to suit a 3 inch suspension lift.
i had a few takeds hiace and commadore,
any thing else?
shep how many inches was your lift o your SWB(in that pic)
Heeyy Haterzzz :lol:
I Love AZ!!! and the controv
Post Posted: Thu Dec 03, 2009 12:27 am
thats dave the dodgy kiwi's car it has a just crusing body lift and HD OME 40mm springs
with vs wagon rear shocks on the front and has 30" MTR's
mine has about 4.5 inch spring lift and i have KYB "S" pack vs wagon rear shocks on the front.
the S pack are apparently a bit longer then the normal wagon and i get a lot of droop out of the
shocks and only need 25mm bumpstop ext. my diff has been moved around 45mm forward as well.
Post Posted: Thu Dec 03, 2009 2:18 am
:O
im a dodgy kiwi as well
Pmsl.
hopfully he can help a brother out :)
show me they strings and how to get away with it,
whats his ausszookas name? "DAVE"?
so you say the wagons shocks in the front are they way to go, do they just slip straight in with out cuttin and welding?
:lol::lol: :rofl::rofl:
Post Posted: Thu Dec 03, 2009 3:15 am
Why would people suggest something that odd ball if it took a lot of work to do it??
Just whack some mog diffs and a 350 chev in. It'll be a hell of a lot of work but geez it'll be good.
The shocks go straight in.
Post Posted: Thu Dec 03, 2009 3:26 am
Soo uhmm,
they go straight in?? :roll:
Post Posted: Thu Dec 03, 2009 4:25 am
Yes, straight in
Post Posted: Thu Dec 03, 2009 6:40 pm
i was looking at my steering column today, and was unsure wether my Sj413 is able for a body lift?
i didnt notice it before but the crossmembers mounts are one peice with the hub?
Post Posted: Thu Dec 03, 2009 6:44 pm
:? :? :? :? What hub?
It will work :wink:
Post Posted: Thu Dec 03, 2009 7:07 pm
"S" pack are shorter, I think you might find that they are "Country" pack instead :wink:
Post Posted: Thu Dec 03, 2009 7:11 pm
the uhmmm,
insidee of the wheel, ill take a pic, needa find my uplaod cord,
uhmm its connected to the inside of the wheel, i forget the name,
Post Posted: Thu Dec 03, 2009 10:23 pm
None of that is effected with a body lift. The body lift simply lifts the body off the chassis with a series of blocks
Post Posted: Fri Dec 04, 2009 2:33 am
extended shackles??
Post Posted: Fri Dec 04, 2009 2:38 am
F*#k that knuckle look's rusty, what's the rest of the car like??
Post Posted: Fri Dec 04, 2009 2:49 am
Brocbeau wrote:
extended shackles??
You don't need them yet.
Do your spring lift and body lift ( if you have to) and worry about shackles later.
Pete
Post Posted: Fri Dec 04, 2009 3:01 am
woh i just had a good look at the pic and yeah i looks like its seen better days, but its not that bad in real life lol, most if is is dirt and mud as well :lol:
and fatzook
yeah i know i haave money for rego and shit next year,a nd a bit on the side for a 3 inch calmini lift, i plan on buying your shackles though
im hoping i wont needa replace the steering (knuckle)
Post Posted: Fri Dec 04, 2009 3:03 am
ohh steknig check my .. uhmm soon to be build up its a reall clean zook
http://www.auszookers.com/index.php?nam ... pic&t=8172
Post Posted: Fri Dec 04, 2009 3:36 am
thats the ones :oops:
mate ditch your sway bar and give ya car a good clean and then fish oil it.
but seriously just drive ya car for a bit and get yourself a workshop manual
and learn how it works then you will get an idea of what you want to do with it.
Post Posted: Fri Dec 04, 2009 3:46 am
Fish oil :?
paint i guess?
Post Posted: Fri Dec 04, 2009 3:52 am
fish oil kills rust :wink: protects metal and is easy to put on.
Users browsing this forum: No registered users and 58 guests
