| Author |
Message |
nath_89
Joined: Sun Nov 29, 2009 10:30 pm Posts: 33 Location: sydney,nsw
 Posted: Wed Dec 02, 2009 2:20 am |
Hi all , im looking at doin a 2 inch bodylift to my 92 WT , should i do this b4 or after a suspenion lift ?? wanna run 31x10.5xr15's also does any one have any tips on the lift do's and dont's any replies appreciated
zookster666
 Posted: Wed Dec 02, 2009 3:11 am |
Beat advise I can offer is avoid body lifts as long as you can I run 31x10.5 with no b/l and I get very little scrubbing
I do run bumpstop spacers and my front guards have been massaged though which helps
just_cruizin
Joined: Sun Jun 25, 2006 11:30 pm Posts: 2867 Location: here
 Posted: Wed Dec 02, 2009 4:19 am |
The body lift is $210, a suspension lift is about $600+. You'll want both eventually anyways so do as your budget allows. Can you fit 31's without a BL, yes, if you intend to bash the yell out of wheel arches with a hammer. if you go the BL you have to do the seams anyway but not the entire guard and firewall.
_________________ greenzook89 wrote: 31zook wrote: Makes me want something similar
shep
Joined: Thu Mar 29, 2007 11:30 pm Posts: 14498 Location: Here there everywhere
 Posted: Wed Dec 02, 2009 11:27 am |
here is a 50mm spring lift and a stretched tight brake line.
Scrawny
Joined: Tue Jan 29, 2008 10:30 pm Posts: 10528 Location: Brissie
 Posted: Wed Dec 02, 2009 2:30 pm |
I have never had a problem with tight brake lines  Maybe they aren't factory ones?? I run the Commo/Hilux shock setup with extended bumpstops in the front and there is still plenty of slack in the line at full extension of the shock.
Scrawny
 Posted: Wed Dec 02, 2009 2:41 pm |
In answer to the original q, do both body and suspension lifts. Extend bumpstops and run long shocks to get the most out of the springs. I did body lift first then suspension but it doesn't really matter which way you do it.
BlueSuzy
Joined: Sun May 04, 2008 11:30 pm Posts: 9717 Location: NSW
 Posted: Wed Dec 02, 2009 4:14 pm |
Nice cleanup
shep
 Posted: Wed Dec 02, 2009 5:53 pm |
ScrawnC wrote: I have never had a problem with tight brake lines  Maybe they aren't factory ones?? I run the Commo/Hilux shock setup with extended bumpstops in the front and there is still plenty of slack in the line at full extension of the shock.
that is HD OME springs with commo shocks. i was surprised just how tight they got.
Brocbeau
Joined: Wed Nov 11, 2009 10:30 pm Posts: 189 Location: GoldCoast Babbey
 Posted: Wed Dec 02, 2009 11:49 pm |
whats a good shock to suit a 3 inch suspension lift.
i had a few takeds hiace and commadore,
any thing else?
shep how many inches was your lift o your SWB(in that pic)
_________________ Heeyy Haterzzz
I Love AZ!!! and the controv
shep
 Posted: Thu Dec 03, 2009 12:27 am |
thats dave the dodgy kiwi's car it has a just crusing body lift and HD OME 40mm springs
with vs wagon rear shocks on the front and has 30" MTR's
mine has about 4.5 inch spring lift and i have KYB "S" pack vs wagon rear shocks on the front.
the S pack are apparently a bit longer then the normal wagon and i get a lot of droop out of the
shocks and only need 25mm bumpstop ext. my diff has been moved around 45mm forward as well.
Brocbeau
 Posted: Thu Dec 03, 2009 2:18 am |
:O
im a dodgy kiwi as well
Pmsl.
hopfully he can help a brother out
show me they strings and how to get away with it,
whats his ausszookas name? "DAVE"?
so you say the wagons shocks in the front are they way to go, do they just slip straight in with out cuttin and welding?
 :lol:  :rofl:
just_cruizin
 Posted: Thu Dec 03, 2009 3:15 am |
Why would people suggest something that odd ball if it took a lot of work to do it??
Just whack some mog diffs and a 350 chev in. It'll be a hell of a lot of work but geez it'll be good.
The shocks go straight in.
Brocbeau
 Posted: Thu Dec 03, 2009 3:26 am |
Soo uhmm,
they go straight in??
just_cruizin
 Posted: Thu Dec 03, 2009 4:25 am |
Yes, straight in
Brocbeau
 Posted: Thu Dec 03, 2009 6:40 pm |
i was looking at my steering column today, and was unsure wether my Sj413 is able for a body lift?
i didnt notice it before but the crossmembers mounts are one peice with the hub?
Scrawny
 Posted: Thu Dec 03, 2009 6:44 pm |
Brocbeau wrote: i didnt notice it before but the crossmembers mounts are one peice with the hub?
 What hub?
It will work
TASSIETOYUKI
Joined: Mon Oct 27, 2008 10:30 pm Posts: 490 Location: Rosevears Tas
 Posted: Thu Dec 03, 2009 7:07 pm |
shep wrote: thats dave the dodgy kiwi's car it has a just crusing body lift and HD OME 40mm springs with vs wagon rear shocks on the front and has 30" MTR's
mine has about 4.5 inch spring lift and i have KYB "S" pack vs wagon rear shocks on the front. the S pack are apparently a bit longer then the normal wagon and i get a lot of droop out of the shocks and only need 25mm bumpstop ext. my diff has been moved around 45mm forward as well.
"S" pack are shorter, I think you might find that they are "Country" pack instead
Brocbeau
 Posted: Thu Dec 03, 2009 7:11 pm |
the uhmmm,
insidee of the wheel, ill take a pic, needa find my uplaod cord,
uhmm its connected to the inside of the wheel, i forget the name,
Scrawny
 Posted: Thu Dec 03, 2009 10:23 pm |
None of that is effected with a body lift. The body lift simply lifts the body off the chassis with a series of blocks
Brocbeau
 Posted: Fri Dec 04, 2009 2:33 am |
extended shackles??
steak_knife
 Posted: Fri Dec 04, 2009 2:38 am |
F*#k that knuckle look's rusty, what's the rest of the car like??
Fatzook
 Posted: Fri Dec 04, 2009 2:49 am |
Brocbeau wrote: extended shackles??
You don't need them yet.
Do your spring lift and body lift ( if you have to) and worry about shackles later.
Pete
Brocbeau
 Posted: Fri Dec 04, 2009 3:01 am |
woh i just had a good look at the pic and yeah i looks like its seen better days, but its not that bad in real life lol, most if is is dirt and mud as well
and fatzook
yeah i know i haave money for rego and shit next year,a nd a bit on the side for a 3 inch calmini lift, i plan on buying your shackles though
im hoping i wont needa replace the steering (knuckle)
Brocbeau
 Posted: Fri Dec 04, 2009 3:03 am |
shep
 Posted: Fri Dec 04, 2009 3:36 am |
TASSIETOYUKI wrote: shep wrote: thats dave the dodgy kiwi's car it has a just crusing body lift and HD OME 40mm springs with vs wagon rear shocks on the front and has 30" MTR's
mine has about 4.5 inch spring lift and i have KYB "S" pack vs wagon rear shocks on the front. the S pack are apparently a bit longer then the normal wagon and i get a lot of droop out of the shocks and only need 25mm bumpstop ext. my diff has been moved around 45mm forward as well. "S" pack are shorter, I think you might find that they are " Country" pack instead
thats the ones
mate ditch your sway bar and give ya car a good clean and then fish oil it.
but seriously just drive ya car for a bit and get yourself a workshop manual
and learn how it works then you will get an idea of what you want to do with it.
Brocbeau
 Posted: Fri Dec 04, 2009 3:46 am |
Fish oil
paint i guess?
shep
 Posted: Fri Dec 04, 2009 3:52 am |
fish oil kills rust  protects metal and is easy to put on.
