It is currently Sun Oct 11, 2026 4:47 pm
Post Posted: Wed Jan 20, 2010 3:54 am
Does anyone know if a coily dash will fit a wt leaf sierra?
Any info appreciated.
TWIN LOCK IT & JUST DRIVE!
Post Posted: Wed Jan 20, 2010 3:57 am
x2
really interested to know if they do
i beleive they do
16zuk did a couple i think to his cars.i dont see a problem with fitment, i beleive the problem would be with the wiring to the dash.
Vehicle: 2001 M18a Jimny
Post Posted: Wed Jan 20, 2010 4:02 am
JCZOOK has done it. Looks very well done too.
http://www.auszookers.com/index.php?nam ... c&start=15
Post Posted: Wed Jan 20, 2010 4:07 am
Cheers for that mate :lol:
Post Posted: Wed Jan 20, 2010 9:59 pm
I'd be interested to know how that dash conversion went. Coiler dashes are lovely, but they weren't designed for folding windscreens. I've been in a soft top that was coil dash converted and it was terribly rattly and wobbly - clearly some of the attachment points are different.
Post Posted: Wed Jan 20, 2010 10:12 pm
pretty sure you have to do your own brackets up, it's usually pretty easy to improve factory mounting arrangements
Post Posted: Thu Jan 21, 2010 7:28 pm
It took me 11 hours start to finish. The coily dash is wider so it wraps around the big windscreen clips at the two sides. I used these as mounts for the coily dash. The metal brackets under the windscreen will need to be chopped off (will make sense when you pull your dash out). The top middle and drivers side mounting holes will line up. You can use leaf or coil heater controls. The mounting hole behind the cigarette lighter will line up. I swapped in a coily bonnet cable as well as they are mounted differently. Also used a coily steering wheel and steering column shroud. Shroud had to be cut abit so the washer jets could work and steering coloumn spaced down. As for wiring the two dashes are completley different but with patience you can just trace each wire on the back of each dash facia. It's definatley worth it it transformed my zook inside
Users browsing this forum: No registered users and 220 guests
