[ 7 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
Junior_91
Joined: Tue Mar 17, 2009 10:30 pm Posts: 1084 Location: Ipswich
 Posted: Wed Jan 20, 2010 3:54 am |
Does anyone know if a coily dash will fit a wt leaf sierra?
Any info appreciated.
_________________ TWIN LOCK IT & JUST DRIVE!
89_tintop
Joined: Fri Aug 07, 2009 11:30 pm Posts: 3159 Location: gold coast
 Posted: Wed Jan 20, 2010 3:57 am |
x2
really interested to know if they do
i beleive they do
16zuk did a couple i think to his cars.i dont see a problem with fitment, i beleive the problem would be with the wiring to the dash.
OMalley
Vehicle: 2001 M18a Jimny
 Posted: Wed Jan 20, 2010 4:02 am |
Junior_91
 Posted: Wed Jan 20, 2010 4:07 am |
OMalley wrote:
Cheers for that mate
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13013 Location: Melbourne
 Posted: Wed Jan 20, 2010 9:59 pm |
I'd be interested to know how that dash conversion went. Coiler dashes are lovely, but they weren't designed for folding windscreens. I've been in a soft top that was coil dash converted and it was terribly rattly and wobbly - clearly some of the attachment points are different.
Saam
Joined: Mon Jun 12, 2006 11:30 pm Posts: 2068 Location: Sunshine Coast
 Posted: Wed Jan 20, 2010 10:12 pm |
pretty sure you have to do your own brackets up, it's usually pretty easy to improve factory mounting arrangements
JCZOOK
Joined: Thu Mar 05, 2009 10:30 pm Posts: 77 Location: Sydney
 Posted: Thu Jan 21, 2010 7:28 pm |
It took me 11 hours start to finish. The coily dash is wider so it wraps around the big windscreen clips at the two sides. I used these as mounts for the coily dash. The metal brackets under the windscreen will need to be chopped off (will make sense when you pull your dash out). The top middle and drivers side mounting holes will line up. You can use leaf or coil heater controls. The mounting hole behind the cigarette lighter will line up. I swapped in a coily bonnet cable as well as they are mounted differently. Also used a coily steering wheel and steering column shroud. Shroud had to be cut abit so the washer jets could work and steering coloumn spaced down. As for wiring the two dashes are completley different but with patience you can just trace each wire on the back of each dash facia. It's definatley worth it it transformed my zook inside
[ 7 posts ] |
Users browsing this forum: Google [Bot] and 136 guests
