It is currently Fri Sep 25, 2026 2:58 am
Post Posted: Thu Dec 02, 2010 8:19 am
G'day chaps,
Quick question
Does anyone know what or how the idle is controlled on a g13bb, Mine idles high, and I'd like to bring it down. Sometimes it idles fine, other times its 1500 odd. No I don't have a vaccuum leak either.
Next question, does anyone know the tacho output on the ecu? I don't have one at the moment, And i'd like to wire it up to the sierra dash if possible.
That is all
GTi Turbo & A LWB Sierra.
Post Posted: Thu Dec 02, 2010 8:21 am
im pretty sure the g13bb ecu wont work with the sierra tacho
Post Posted: Thu Dec 02, 2010 11:44 pm
I'm glad you are getting around to fixing these problems! When I had it, it never idled that high. Have you got a Jimny service manual?
I think Spamwell hooked up his sierra with a jimny tacho input, dont know how though.
Post Posted: Fri Dec 03, 2010 12:08 am
Sams Coily had an aftermarket tacho fitted.
Post Posted: Fri Dec 03, 2010 12:18 am
I use a baleno one, with the baleno twin coil motor...
The g13bbs are twin coil also. So they should be similar. Tried hunting down a jim cluster?
Post Posted: Fri Dec 03, 2010 8:20 pm
i don't know if this helps but my g16b started to idle high( and running a bit rough) i just gave it a full service now its back to normal
Post Posted: Fri Dec 03, 2010 8:24 pm
tuffcoily is parting out a jimny with a g13bb
Post Posted: Wed Dec 08, 2010 9:23 am
Hmmm, may possibly have to do some investigation myself then!
Currently it has four bent rods. Hydraulic'd it in a river on saturday,
Machine shop has bits coming for it, should have new rods, rings & bearings friday arvo.
Then I'll be back onto the idle issue and tacho. Has anyone got a jimny ecu pin out for g13bb? and / or service manual?
Cheers guys, Simon.
Post Posted: Wed Dec 08, 2010 9:24 am
pics of your variable compression rods...
Post Posted: Wed Dec 08, 2010 9:34 am
g16b does this when the MAF is a bit dirty, are they a similar setup?
Post Posted: Wed Dec 08, 2010 9:56 am
you have the pic i took Gus, you upload it, I haven't taken it off my iDingle to my laptop yet!
Post Posted: Wed Dec 08, 2010 9:58 am
Nope, map unfortunately. One thing I did notice is the idle is alot lower when the alternator is connected, but I've checked my charge rate and sense wire to the alt, and is working fine!
Post Posted: Wed Dec 08, 2010 10:15 am
Re-set your base idle, it should have a air bypass screw in the throttle body, just unplug the IAC & adjust the screw till you get the idle you want, then plug it back in..
I run mine disconnected all the time, just run's off base idle, even with P/s..
Post Posted: Wed Dec 08, 2010 10:18 am
it's still stuck inside my iFail 4... :wink:
Post Posted: Wed Dec 08, 2010 10:19 am
Thanks mate, thats exactly what I was after! Once I put it back together (hopefully sunday, but have my work chrissy dinner sat night) I'll try that!
Post Posted: Wed Dec 08, 2010 2:15 pm
I have a jimny manual I think however it is 5000km east of me at the moment, I get back from Perth Sunday so during the week one night - or just google one :)
Users browsing this forum: Google [Bot] and 129 guests
