| Author |
Message |
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Tue Feb 07, 2012 9:29 am |
Got too much crap here so some of it has to go...
WT rear diff housing (bare).
Has had the perches moved to NT spacing and had 20mm shaved from the bottom for better ground clearance. Also has brake line locating tabs on each side in readiness for a disc brake conversion. Painted gloss black, ready to assemble. SOLD
Maruti cab with extras.
1 Maruti cab section. 1 roof section. 1 Maruti targa bar. 1 Maruti LWB steel filler panel. 1 Suzuki SWB steel filler panel. 8 Sierra tintop rear windows. Most with demister. My plan was to take a mold and reproduce these using tintop rear windows as they are a tiny bit larger and much easier to get. BUSINESS OPPORTUNITY for the right person. $900 PICKUP ONLY
SIERRA & VITARA Radiators Brand new in the box, alloy cored, plastic tanked radiators to suit 1.3-1.6 Sierra and 1.6 Vitara. $160 delivered anywhere in Aust. Sold out of Sierra rads. Will advise when more are in stock.
Vitara 5.12 front centre Complete 5.12 front centre VGC. SOLD
Simex Centipede ET2 32x9.5 Set of four 32x9.5 Simex Extreme Centipedes. Very good tread (13mm). Few nicks and cuts but nothing serious. $800
38mm Wheel spacers Set of four inch and a half (38mm) aluminium wheelspacers to suit Sierra or Vitara. $200
Bathurst Globe mag wheels 15x7 Set of four Globe 5 spoke alloy wheels in 15x7 with 0 offset. They have 2nd valve stem holes fitted for internal beadlocks but this isn't a drama if you don't have beadlocks. $200
WT LWB rear tailshaft Custom made super heavy wall 1.3 WT lwb rear tailshaft. SOLD
ARB OME +40 rear springs Brand new ARB OME rear springs (pair). Cost $250, sell $200.
WT long side (pass) rear axle WT LH rear axle with backing plate and drum. No twist in splines. $75
G13 engine (reco'd) G13 engine, standard bore with new rings and bearings as well as a fully reco'd head fitted. Has new oil pump too. Hasn't been started since. SOLD
Vitara grille (white) VGC Vitara 89-94? grille. No cracks or broken bits. $50
1.3 diff centres 2 X NT front... $100 each 1 X NT rear... $150 1 X WT rear... SOLD
Federal Couragia 30x9.5 muddy One only, 30x9.5 Federal Couragia mud tyre. Has 8mm or so tread. $50
want33s
 Posted: Thu Feb 09, 2012 8:30 am |
want33s
 Posted: Sun Feb 12, 2012 8:32 am |
sogone
Joined: Mon Oct 25, 2010 11:29 am Posts: 2070 Location: Darwin
 Posted: Sun Feb 12, 2012 8:49 am |
sogone
want33s
 Posted: Sun Feb 12, 2012 8:53 am |
sogone wrote: Got any (WT Sierra) transfers? Sorry, no.
boost=money
Joined: Sun Aug 16, 2009 11:30 pm Posts: 240 Location: brisbane
 Posted: Sun Feb 12, 2012 9:18 am |
will come grab spacers next saturday if still there
want33s
 Posted: Sun Feb 12, 2012 9:24 am |
boost=money wrote: will come grab spacers next saturday if still there Cool.. I can post them for $20.
boost=money
 Posted: Sun Feb 12, 2012 4:57 pm |
i will come up and grab them next weekend if u can hold them for me. heading up to barra park so on the way thanks mate
055ETH
Joined: Sun Oct 23, 2011 9:05 pm Posts: 383 Location: Brisbane
Vehicle: 94 Sierra,99 gv, s13 Silvia
 Posted: Sun Feb 12, 2012 9:57 pm |
Any difference in wt and nt diff centers?? Can u put nt centers in a wt?
want33s
 Posted: Mon Feb 13, 2012 8:31 am |
055ETH wrote: Any difference in wt and nt diff centers?? Can u put nt centers in a wt? NT centres will bolt straight into WT housings and the axles fit. The differences are: NT 3.9:1 WT 3.7:1......... That means NT is about 5% lower geared. NT has a smaller drive flange pattern but the flanges on the diffs or the tailshafts can be changed easily. NT front diffs are 4 pinion which are stronger than WT fronts which are only 2 pinion.
sambo91
Joined: Sun Jan 23, 2011 1:40 am Posts: 150 Location: gold coast
 Posted: Mon Feb 13, 2012 12:57 pm |
I was just wondering if you had a sierra body lying around there with the left hand sill in tact ? I'm looking to chop the old one which i found a heap of bog and crap in it and weld in another one. My Sierra is an sj80 so the wt or nt one should be fine also =) Thanks alot for your time. Regards Sambo.
Zook_Fan
Joined: Thu Mar 13, 2008 10:30 pm Posts: 4531 Location: Toowoomba
 Posted: Mon Feb 13, 2012 1:07 pm |
Got any stock WT diff housings?
want33s
 Posted: Mon Feb 13, 2012 2:22 pm |
Zook_Fan wrote: Got any stock WT diff housings? Yep. Got a standard WT front $75 plus freight. Got a shaved and NT'd WT rear $100 plus freight.
want33s
 Posted: Wed Feb 15, 2012 2:09 pm |
Diff housing sold pending payment.
Gadzuks
Joined: Tue Jul 05, 2011 4:44 am Posts: 86 Location: Penrith
 Posted: Thu Feb 16, 2012 3:21 pm |
Can you please post some pics of the rims?
want33s
 Posted: Thu Feb 16, 2012 5:50 pm |
Gadzuks wrote: Can you please post some pics of the rims? How they looked when I first fitted them after hours sanding and polishing.  How they look now.
want33s
 Posted: Thu Feb 23, 2012 7:10 pm |
1st post edited with items sold.
swifty_ano
Joined: Tue Jun 29, 2010 4:17 am Posts: 1664 Location: Brisbane, QLD
 Posted: Fri Feb 24, 2012 5:34 am |
How much for a vitara radiator and ill pick up? Do you have both sizes?
want33s
 Posted: Fri Feb 24, 2012 6:56 am |
swifty_ano wrote: How much for a vitara radiator and ill pick up? Do you have both sizes? I have one Vit rad left. Pretty sure it says SQ416 on the box. $140 if you pick up.
swifty_ano
 Posted: Fri Feb 24, 2012 10:20 am |
Sold. I'll measure mine after work and give you a call
want33s
 Posted: Sat Feb 25, 2012 3:49 pm |
Rad is no good to Swifty_Ano, his is smaller so this one is still available.
Shansh
Joined: Sun May 23, 2010 9:35 am Posts: 1816 Location: Goulburn NSW
Vehicle: Ducati Monster
 Posted: Sat Feb 25, 2012 4:48 pm |
rad arrived late last week, thanks Jas
want33s
 Posted: Wed Mar 14, 2012 12:37 pm |
Shansh wrote: rad arrived late last week, thanks Jas No worries Shan.
Zook_Fan
 Posted: Wed Mar 14, 2012 12:44 pm |
Do the alloy radiators cool any better than copper core?
want33s
 Posted: Wed Mar 14, 2012 3:35 pm |
Zook_Fan wrote: Do the alloy radiators cool any better than copper core? I have never directly compared them but I can say that my 1.6 in Sierra with Sierra rad never got hot unless I was flogging it on the limiter for 5 minutes or more, usually low range in the bottom of a muddy gully, and always cooled down quickly when let idle for a few minutes. I don't have any 1.3 rads at the moment. I do have a 1.6 Vit rad here that will fit a Sierra with modified brackets.
