It is currently Wed Oct 28, 2026 5:58 pm
Post Posted: Tue Feb 07, 2012 9:29 am
Got too much crap here so some of it has to go...
WT rear diff housing (bare).
Has had the perches moved to NT spacing and had 20mm shaved from the bottom for better ground clearance. Also has brake line locating tabs on each side in readiness for a disc brake conversion.
Painted gloss black, ready to assemble.
SOLD
Maruti cab with extras.
1 Maruti cab section.
1 roof section.
1 Maruti targa bar.
1 Maruti LWB steel filler panel.
1 Suzuki SWB steel filler panel.
8 Sierra tintop rear windows. Most with demister.
My plan was to take a mold and reproduce these using tintop rear windows as they are a tiny bit larger and much easier to get.
BUSINESS OPPORTUNITY for the right person.
$900
PICKUP ONLY
SIERRA & VITARA Radiators
Brand new in the box, alloy cored, plastic tanked radiators to suit 1.3-1.6 Sierra and 1.6 Vitara.
$160 delivered anywhere in Aust.
Sold out of Sierra rads. Will advise when more are in stock.
Vitara 5.12 front centre
Complete 5.12 front centre VGC.
SOLD
Simex Centipede ET2 32x9.5
Set of four 32x9.5 Simex Extreme Centipedes.
Very good tread (13mm). Few nicks and cuts but nothing serious.
$800
38mm Wheel spacers
Set of four inch and a half (38mm) aluminium wheelspacers to suit Sierra or Vitara.
$200
Bathurst Globe mag wheels 15x7
Set of four Globe 5 spoke alloy wheels in 15x7 with 0 offset.
They have 2nd valve stem holes fitted for internal beadlocks but this isn't a drama if you don't have beadlocks.
$200
WT LWB rear tailshaft
Custom made super heavy wall 1.3 WT lwb rear tailshaft.
SOLD
ARB OME +40 rear springs
Brand new ARB OME rear springs (pair).
Cost $250, sell $200.
WT long side (pass) rear axle
WT LH rear axle with backing plate and drum. No twist in splines.
$75
G13 engine (reco'd)
G13 engine, standard bore with new rings and bearings as well as a fully reco'd head fitted. Has new oil pump too.
Hasn't been started since.
SOLD
Vitara grille (white)
VGC Vitara 89-94? grille. No cracks or broken bits.
$50
1.3 diff centres
2 X NT front... $100 each
1 X NT rear... $150
1 X WT rear... SOLD
Federal Couragia 30x9.5 muddy
One only, 30x9.5 Federal Couragia mud tyre. Has 8mm or so tread.
$50
Post Posted: Thu Feb 09, 2012 8:30 am
bump.
Post Posted: Sun Feb 12, 2012 8:32 am
First post edited.
Post Posted: Sun Feb 12, 2012 8:49 am
Got any transfers?
WT Sierra.
Post Posted: Sun Feb 12, 2012 8:53 am
sogone wrote:
Got any (WT Sierra)
transfers?
Sorry, no.
Post Posted: Sun Feb 12, 2012 9:18 am
will come grab spacers next saturday if still there
Post Posted: Sun Feb 12, 2012 9:24 am
Cool.. I can post them for $20.
Post Posted: Sun Feb 12, 2012 4:57 pm
i will come up and grab them next weekend if u can hold them for me. heading up to barra park so on the way thanks mate
Vehicle: 94 Sierra,99 gv, s13 Silvia
Post Posted: Sun Feb 12, 2012 9:57 pm
Any difference in wt and nt diff centers?? Can u put nt centers in a wt?
Post Posted: Mon Feb 13, 2012 8:31 am
NT centres will bolt straight into WT housings and the axles fit.
The differences are:
NT 3.9:1
WT 3.7:1......... That means NT is about 5% lower geared.
NT has a smaller drive flange pattern but the flanges on the diffs or the tailshafts can be changed easily.
NT front diffs are 4 pinion which are stronger than WT fronts which are only 2 pinion.
Post Posted: Mon Feb 13, 2012 12:57 pm
I was just wondering if you had a sierra body lying around there with the left hand sill in tact ?
I'm looking to chop the old one which i found a heap of bog and crap in it and weld in another one.
My Sierra is an sj80 so the wt or nt one should be fine also =)
Thanks alot for your time.
Regards Sambo.
Post Posted: Mon Feb 13, 2012 1:07 pm
Got any stock WT diff housings?
Post Posted: Mon Feb 13, 2012 2:22 pm
Yep. Got a standard WT front $75 plus freight.
Got a shaved and NT'd WT rear $100 plus freight.
Post Posted: Wed Feb 15, 2012 2:09 pm
Diff housing sold pending payment.
Post Posted: Thu Feb 16, 2012 3:21 pm
Can you please post some pics of the rims?
Post Posted: Thu Feb 16, 2012 5:50 pm
How they looked when I first fitted them after hours sanding and polishing.
How they look now.
Post Posted: Thu Feb 23, 2012 7:10 pm
1st post edited with items sold.
Post Posted: Fri Feb 24, 2012 5:34 am
How much for a vitara radiator and ill pick up?
Do you have both sizes?
Post Posted: Fri Feb 24, 2012 6:56 am
I have one Vit rad left.
Pretty sure it says SQ416 on the box.
$140 if you pick up.
Post Posted: Fri Feb 24, 2012 10:20 am
Sold. I'll measure mine after work and give you a call
Post Posted: Sat Feb 25, 2012 3:49 pm
Rad is no good to Swifty_Ano, his is smaller so this one is still available.
Vehicle: Ducati Monster
Post Posted: Sat Feb 25, 2012 4:48 pm
rad arrived late last week, thanks Jas
Post Posted: Wed Mar 14, 2012 12:37 pm
No worries Shan. :D
Post Posted: Wed Mar 14, 2012 12:44 pm
Do the alloy radiators cool any better than copper core?
Post Posted: Wed Mar 14, 2012 3:35 pm
I have never directly compared them but I can say that my 1.6 in Sierra with Sierra rad never got hot unless I was flogging it on the limiter for 5 minutes or more, usually low range in the bottom of a muddy gully, and always cooled down quickly when let idle for a few minutes.
I don't have any 1.3 rads at the moment.
I do have a 1.6 Vit rad here that will fit a Sierra with modified brackets.
Users browsing this forum: No registered users and 71 guests
