[ 6 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
kyzermattingley
Joined: Sat Dec 05, 2009 10:30 pm Posts: 281 Location: brisbane
 Posted: Mon Sep 15, 2014 12:05 am |
As mentioned I have the following stuff to get rid of, pic to follow
1- modified bundera housing, axles etc -all brackets removed from housing, housing then ground smooth, axles have been redrilled (by Driveline Services) to suzi 5stud pattern with new studs fitted, comes with Jimny front disks that I was using to do a disk brake rear conversion, comes with bearing cups and other bits and pieces. $200ono. Willing to weld on brackets / shave pumpkin / brace / disk brackets for more $
SOLD2- Sierra transfer to Jimny jig -puts the transfer about 30mm higher and 30mm further forward, I used this to make my brackets for my Sierra transfer into my Jimny, fits better than other kits on the market $100onoSOLD
SOLD3- ARB locker wiring, front locker switch and pump switch -the box is just missing the diff centre $25 SOLD
4- hilux complete front diff -wheel to wheel, not sure what ratio centre, have all the parts to convert to hi-pinion with rear mounted toe rod $150
5- LROR Suzuki to Toyota diff conversion flanges -Suzuki tail shaft pattern to Toyota diff pinion spline, used for putting Toyota axles into your Suzuki $50ea. Or $80pair
SOLD6- Jimny front diff brackets -front diff brackets that I plasma cut from a Jimny diff housing $10SOLD
7- Toyota 4.1 hi-pinion 8" front diff centre -removed from an 80series front diff, great condition, never got around to using $100
Location- Murarrie, Brisbane, QLD
CONTACT- Brett 0433191205
Willing to ship stuff at your expense
Last edited by kyzermattingley on Mon Sep 22, 2014 3:55 pm, edited 4 times in total.
dougies_tx5turbo
Joined: Tue May 25, 2010 10:56 am Posts: 1051 Location: north brisbane
 Posted: Mon Sep 15, 2014 12:34 am |
Mate will take 1 ,2 and 6 pm sent and I well txt in the morning and can pick up tomorrow Monday afternoon thank Doug Edit maybe take all the staff needed to convert to jimny front and rear
Sookie
Vehicle: Sj51t
 Posted: Mon Sep 15, 2014 7:54 am |
Hey mate I'll take locker wiring and switch ect
Zook_Fan
Joined: Thu Mar 13, 2008 10:30 pm Posts: 4531 Location: Toowoomba
 Posted: Mon Sep 15, 2014 9:08 am |
In for the locker wiring etc. if Sookie pulls out.
nick_bj40
Joined: Sun Apr 19, 2009 11:30 pm Posts: 114 Location: wollongong
 Posted: Wed Sep 17, 2014 8:07 pm |
I'm keen on the high pinion centre but how much would freight be to nsw 2526?
kyzermattingley
 Posted: Sun Sep 21, 2014 6:03 pm |
Lockers switches and wiring sold
[ 6 posts ] |
