It is currently Fri Nov 13, 2026 2:20 pm
Post Posted: Mon Sep 15, 2014 12:05 am
As mentioned I have the following stuff to get rid of, pic to follow
1- modified bundera housing, axles etc -all brackets removed from housing, housing then ground smooth, axles have been redrilled (by Driveline Services) to suzi 5stud pattern with new studs fitted, comes with Jimny front disks that I was using to do a disk brake rear conversion, comes with bearing cups and other bits and pieces.
$200ono. Willing to weld on brackets / shave pumpkin / brace / disk brackets for more $
SOLD2- Sierra transfer to Jimny jig -puts the transfer about 30mm higher and 30mm further forward, I used this to make my brackets for my Sierra transfer into my Jimny, fits better than other kits on the market
$100onoSOLD
SOLD3- ARB locker wiring, front locker switch and pump switch -the box is just missing the diff centre
$25 SOLD
4- hilux complete front diff -wheel to wheel, not sure what ratio centre, have all the parts to convert to hi-pinion with rear mounted toe rod
$150
5- LROR Suzuki to Toyota diff conversion flanges -Suzuki tail shaft pattern to Toyota diff pinion spline, used for putting Toyota axles into your Suzuki
$50ea. Or $80pair
SOLD6- Jimny front diff brackets -front diff brackets that I plasma cut from a Jimny diff housing
$10SOLD
7- Toyota 4.1 hi-pinion 8" front diff centre -removed from an 80series front diff, great condition, never got around to using
$100
Location- Murarrie, Brisbane, QLD
CONTACT- Brett 0433191205
Willing to ship stuff at your expense
Last edited by kyzermattingley on Mon Sep 22, 2014 3:55 pm, edited 4 times in total.
Post Posted: Mon Sep 15, 2014 12:34 am
Mate will take 1 ,2 and 6 pm sent and I well txt in the morning and can pick up tomorrow Monday afternoon thank Doug
Edit maybe take all the staff needed to convert to jimny front and rear
Vehicle: Sj51t
Post Posted: Mon Sep 15, 2014 7:54 am
Hey mate I'll take locker wiring and switch ect
Post Posted: Mon Sep 15, 2014 9:08 am
In for the locker wiring etc. if Sookie pulls out.
Post Posted: Wed Sep 17, 2014 8:07 pm
I'm keen on the high pinion centre but how much would freight be to nsw 2526?
Post Posted: Sun Sep 21, 2014 6:03 pm
Lockers switches and wiring sold
Users browsing this forum: Google Adsense [Bot] and 5 guests
