Joined: Sat Feb 09, 2013 10:47 pm Posts: 23 Location: Gold Coast
Vehicle: 1995 suzuki sierra, 30's, Lift
Posted: Thu Feb 26, 2015 6:56 am
Modifications include - Swift Gti motor conversion – 1995 motor - 4 - 2 -1 Extractors and sports exhaust with high flow cat. 2 1/4inch - HD Excedy Clutch - 2inch EFS Spring Lift - 2inch Aluminum Body Lift - Custom Bullbar with external full roll cage - (Will part it, for the right price) - Rear locker installed professionally, rear axle seals done at the same time - $400 in total. - SAAS Bucket Seats – Not the cheap nasty ones - Custom Dashboard: o Water Temperature Gauge (need connecting) o Oil Pressure Gauge (need connecting) o Oil Temperature Gauge (need connecting) o 6 Switches – 2 hooked up already o Oricom UHF built in o 2 x 12volt outlets (Narva brand) o Carbon Fiber wrapped - HID Headlights amazing coverage - Tray Liner been put on the floor in the whole truck - LED Map Light Installed - Rear draw system with LED lights in the draws - Tie down point in the back rated to 3Ton x 2 - Re-painted dashboard - 30inch Maxxis Bighorn Mud Tires, 50% left, never let you down - 15inch Sunraiser Rims - Rubber flares to cover bigger tires (Not the shitty garden edging ones) - Front Hubs reconditioned at 5000km ago, Drivers needs doing - Timing Belt and water pump all done as well - Jerry Can holder on the back tail gate – Includes jerry can - Rego till July with RWC - Gearbox bush replaced - Transfer case mount replaced - Rear Brakes replaced –both shoes and cylinders - Rear main seal replaced - Diff, Gearbox and transfer case oils replaced - Old bolts have been replaced with new ones - Can provide all receipts with sale - Comes with a range of different parts
I have owned this little BEAST for just over a year now but it’s time to grow up a little and hand over the car to someone else with just as much enthusiasm for 4x4ing as I do. This zook has a lot to offer. It is honestly the most reliable car I have owned and always gets a look wherever I go. This car has traveled to country Australia and not once did it miss a beat. It does have its flaws no air con, but makes up for them in reliability, character, and the enjoyment you will get out of it.
It’s a fun car to drive and my girlfriend would say that I love it more then her. It’s my pride and joy and that can be seen with all that I've done to it.
The car does have a full External Roll Cage - although I'll part it if someone offers me the right coin $$
Users browsing this forum: No registered users and 26 guests
