It is currently Fri Nov 13, 2026 8:16 pm
Vehicle: 1995 suzuki sierra, 30's, Lift
Post Posted: Thu Feb 26, 2015 6:56 am
Modifications include
- Swift Gti motor conversion – 1995 motor
- 4 - 2 -1 Extractors and sports exhaust with high flow cat. 2 1/4inch
- HD Excedy Clutch
- 2inch EFS Spring Lift
- 2inch Aluminum Body Lift
- Custom Bullbar with external full roll cage - (Will part it, for the right price)
- Rear locker installed professionally, rear axle seals done at the same time - $400 in total.
- SAAS Bucket Seats – Not the cheap nasty ones
- Custom Dashboard:
o Water Temperature Gauge (need connecting)
o Oil Pressure Gauge (need connecting)
o Oil Temperature Gauge (need connecting)
o 6 Switches – 2 hooked up already
o Oricom UHF built in
o 2 x 12volt outlets (Narva brand)
o Carbon Fiber wrapped
- HID Headlights amazing coverage
- Tray Liner been put on the floor in the whole truck
- LED Map Light Installed
- Rear draw system with LED lights in the draws
- Tie down point in the back rated to 3Ton x 2
- Re-painted dashboard
- 30inch Maxxis Bighorn Mud Tires, 50% left, never let you down
- 15inch Sunraiser Rims
- Rubber flares to cover bigger tires (Not the shitty garden edging ones)
- Front Hubs reconditioned at 5000km ago, Drivers needs doing
- Timing Belt and water pump all done as well
- Jerry Can holder on the back tail gate – Includes jerry can
- Rego till July with RWC
- Gearbox bush replaced
- Transfer case mount replaced
- Rear Brakes replaced –both shoes and cylinders
- Rear main seal replaced
- Diff, Gearbox and transfer case oils replaced
- Old bolts have been replaced with new ones
- Can provide all receipts with sale
- Comes with a range of different parts
I have owned this little BEAST for just over a year now but it’s time to grow up a little and hand over the car to someone else with just as much enthusiasm for 4x4ing as I do. This zook has a lot to offer. It is honestly the most reliable car I have owned and always gets a look wherever I go. This car has traveled to country Australia and not once did it miss a beat. It does have its flaws no air con, but makes up for them in reliability, character, and the enjoyment you will get out of it.
It’s a fun car to drive and my girlfriend would say that I love it more then her. It’s my pride and joy and that can be seen with all that I've done to it.
The car does have a full External Roll Cage - although I'll part it if someone offers me the right coin $$
Message me you mobile number for photos!!
ASKING $7995
Post Posted: Fri Feb 27, 2015 11:12 am
Pm sent about cage
Post Posted: Fri Mar 06, 2015 8:48 am
BUMPPP
Vehicle: 1990 sierra , 1.3 gti
Post Posted: Sat Mar 14, 2015 1:08 pm
Still got cage ?
Pm'd
Users browsing this forum: No registered users and 21 guests
