It is currently Fri Oct 30, 2026 5:18 pm
Post Posted: Sat Sep 08, 2012 7:12 pm
1300 Sierra radiator with an electric fan fitted - $50
North Brisbane
Post Posted: Sat Sep 15, 2012 7:59 am
This is still for sale
Vehicle: Coily "Ute"
Post Posted: Thu Sep 27, 2012 10:03 am
g'day 2stroker,
Do you know if this will fit a coily?
Scott
Vehicle: SJ80, SE416
Post Posted: Thu Sep 27, 2012 10:24 am
A WT radiator will fit in a coily - but you will need to fix your fan shroud on with cable ties as the holes are in a slightly different position. The drain tap is also in a slightly different position so you need to cut the shroud around this also. I know the mounting rails are different also but I can't remember if new holes are required. I have a WT radiator in one of my coilies.
Post Posted: Thu Sep 27, 2012 2:12 pm
can i just tek screw it on? haha
I dont mind making it fit, as long as it works.
Cheers Reubs. I dont think this will be the last time you answer one of my questions
PM sent 2stroker
Post Posted: Thu Sep 27, 2012 5:42 pm
Thanks Reubs
Vehicle: Coily.
Post Posted: Wed Mar 29, 2017 8:28 am
Old Thread that came up in a search,does anyone know the best place to pick up a Radiator for a Coily...
Apparently the pre-1996 ones are different. ..............TIA.
Regards All from far Northern NSW.
Vehicle: Sierra g16 efi..and Sierra GTi
Post Posted: Wed Mar 29, 2017 9:02 am
Don't forget to disconnect that before going into deep puddles.. The water pushed the blades against the radiator and damages all the fins and sometimes blades snap off ....
Post Posted: Wed Mar 29, 2017 9:44 am
Fiollowed by forgetting to turn it back on and doing a head gasket.
Vehicle: Which one?
Post Posted: Wed Mar 29, 2017 1:35 pm
Wire it up to a really flippin' annoying, mega-loud piezo buzzer in the cab that screams at you when it's manually switched off. pompoms
Post Posted: Wed Mar 29, 2017 3:33 pm
There's one listed on eBay for an sj80 $105 harry.
Post Posted: Wed Mar 29, 2017 5:09 pm
Yet nobody does.
Vehicle: Coily.
Post Posted: Wed Mar 29, 2017 6:53 pm
Thanks for reply Jack,any chance of a link?
I was told the Ebay ones can be made to fit but don't have the bolt holes for the fan shroud,not sure if thats correct thou.
Post Posted: Wed Mar 29, 2017 8:57 pm
If I had a thermo off switch (or a thermo full stop) I'd also have a coolant temperature alarm, which is something I'd have on most 4wds anyway.
Vehicle: Coily.
Post Posted: Mon Apr 10, 2017 1:42 pm
Bump.......anyone know where to get a new radiator for a Coily?? TIA
Vehicle: lj50 soft top76
Post Posted: Mon Apr 10, 2017 6:31 pm
ebay get an alloy one
Vehicle: Coily.
Post Posted: Mon Apr 10, 2017 9:24 pm
Thanks for reply,i might have to do that and make it fit.I was told the fan shroud won't fit though.
Post Posted: Mon Apr 17, 2017 2:57 pm
Yeah i got one when i did the 1.6 conversion, from memory on one side a lip need to be cut from the shroud then one side will bolt up and i used zipties on the other side to get it back on the road however the zipties are still there 5 months later :lol:
Vehicle: Coily.
Post Posted: Tue Apr 18, 2017 9:08 am
Ok,Thanks,is the fan shroud necessary or is just a safety thing?...
Post Posted: Wed Apr 19, 2017 8:58 am
No, the shroud is absolutely necessary for correct cooling. The fan and radiator can't work without it.
Vehicle: Coily.
Post Posted: Wed Apr 19, 2017 10:29 am
Ok,Thanks again,i'll find a way to get it mounted,perhaps the earlier shrouds will fit and clear the Coily fan.
Users browsing this forum: No registered users and 38 guests
