| Author |
Message |
2stroker
Joined: Sun Sep 07, 2008 11:30 pm Posts: 2689 Location: North Brisbane
 Posted: Sat Sep 08, 2012 7:12 pm |
1300 Sierra radiator with an electric fan fitted - $50 North Brisbane
2stroker
 Posted: Sat Sep 15, 2012 7:59 am |
shlonga86
Joined: Thu Jul 14, 2011 1:56 pm Posts: 151 Location: Caboolture, QLD
Vehicle: Coily "Ute"
 Posted: Thu Sep 27, 2012 10:03 am |
g'day 2stroker,
Do you know if this will fit a coily?
Scott
Reubs
Joined: Wed Sep 09, 2009 11:30 pm Posts: 1522 Location: Brisbane
Vehicle: SJ80, SE416
 Posted: Thu Sep 27, 2012 10:24 am |
shlonga86 wrote: Do you know if this will fit a coily? A WT radiator will fit in a coily - but you will need to fix your fan shroud on with cable ties as the holes are in a slightly different position. The drain tap is also in a slightly different position so you need to cut the shroud around this also. I know the mounting rails are different also but I can't remember if new holes are required. I have a WT radiator in one of my coilies.
shlonga86
 Posted: Thu Sep 27, 2012 2:12 pm |
can i just tek screw it on? haha
I dont mind making it fit, as long as it works.
Cheers Reubs. I dont think this will be the last time you answer one of my questions
PM sent 2stroker
2stroker
 Posted: Thu Sep 27, 2012 5:42 pm |
HarryHoudini
Joined: Fri Jul 01, 2011 12:34 am Posts: 360 Location: Northern NSW Australia.
Vehicle: Coily.
 Posted: Wed Mar 29, 2017 8:28 am |
Old Thread that came up in a search,does anyone know the best place to pick up a Radiator for a Coily... Apparently the pre-1996 ones are different. ..............TIA.
_________________ Regards All from far Northern NSW.
Toomanycars
Joined: Thu Aug 18, 2016 1:47 pm Posts: 324 Location: Under a car in Brisbane scratching my head
Vehicle: Sierra g16 efi..and Sierra GTi
 Posted: Wed Mar 29, 2017 9:02 am |
Don't forget to disconnect that before going into deep puddles.. The water pushed the blades against the radiator and damages all the fins and sometimes blades snap off ....
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13014 Location: Melbourne
 Posted: Wed Mar 29, 2017 9:44 am |
Fiollowed by forgetting to turn it back on and doing a head gasket.
henno
Joined: Tue Jul 23, 2013 5:56 pm Posts: 2439 Location: Brisbane
Vehicle: Which one?
 Posted: Wed Mar 29, 2017 1:35 pm |
Gwagensteve wrote: Fiollowed by forgetting to turn it back on and doing a head gasket. Wire it up to a really flippin' annoying, mega-loud piezo buzzer in the cab that screams at you when it's manually switched off.
J--A--C--K
Joined: Tue Jan 10, 2012 3:48 am Posts: 253 Location: melbourne
 Posted: Wed Mar 29, 2017 3:33 pm |
There's one listed on eBay for an sj80 $105 harry.
Gwagensteve
 Posted: Wed Mar 29, 2017 5:09 pm |
henno wrote: Gwagensteve wrote: Fiollowed by forgetting to turn it back on and doing a head gasket. Wire it up to a really flippin' annoying, mega-loud piezo buzzer in the cab that screams at you when it's manually switched off.  Yet nobody does.
HarryHoudini
Vehicle: Coily.
 Posted: Wed Mar 29, 2017 6:53 pm |
J--A--C--K wrote: There's one listed on eBay for an sj80 $105 harry. Thanks for reply Jack,any chance of a link? I was told the Ebay ones can be made to fit but don't have the bolt holes for the fan shroud,not sure if thats correct thou.
sideways
Joined: Fri Oct 29, 2010 1:53 pm Posts: 5946 Location: Northcliffe, W.A.
 Posted: Wed Mar 29, 2017 8:57 pm |
If I had a thermo off switch (or a thermo full stop) I'd also have a coolant temperature alarm, which is something I'd have on most 4wds anyway.
HarryHoudini
Vehicle: Coily.
 Posted: Mon Apr 10, 2017 1:42 pm |
Bump.......anyone know where to get a new radiator for a Coily?? TIA
thorno
Vehicle: lj50 soft top76
 Posted: Mon Apr 10, 2017 6:31 pm |
HarryHoudini
Vehicle: Coily.
 Posted: Mon Apr 10, 2017 9:24 pm |
thorno wrote: ebay get an alloy one Thanks for reply,i might have to do that and make it fit.I was told the fan shroud won't fit though.
Joe
Joined: Sat Jul 04, 2009 11:30 pm Posts: 49041 Location: Rockingham W.A
 Posted: Mon Apr 17, 2017 2:57 pm |
HarryHoudini wrote: thorno wrote: ebay get an alloy one Thanks for reply,i might have to do that and make it fit.I was told the fan shroud won't fit though. Yeah i got one when i did the 1.6 conversion, from memory on one side a lip need to be cut from the shroud then one side will bolt up and i used zipties on the other side to get it back on the road however the zipties are still there 5 months later
_________________ Joe likes boobs ( . )( . ) ( ° )( ° )
HarryHoudini
Vehicle: Coily.
 Posted: Tue Apr 18, 2017 9:08 am |
Joe wrote: HarryHoudini wrote: thorno wrote: ebay get an alloy one Thanks for reply,i might have to do that and make it fit.I was told the fan shroud won't fit though. Yeah i got one when i did the 1.6 conversion, from memory on one side a lip need to be cut from the shroud then one side will bolt up and i used zipties on the other side to get it back on the road however the zipties are still there 5 months later  Ok,Thanks,is the fan shroud necessary or is just a safety thing?...
Gwagensteve
 Posted: Wed Apr 19, 2017 8:58 am |
No, the shroud is absolutely necessary for correct cooling. The fan and radiator can't work without it.
HarryHoudini
Vehicle: Coily.
 Posted: Wed Apr 19, 2017 10:29 am |
Ok,Thanks again,i'll find a way to get it mounted,perhaps the earlier shrouds will fit and clear the Coily fan.
