| Author |
Message |
laurie
Joined: Fri Oct 31, 2008 10:30 pm Posts: 1540 Location: Blackbutt
Vehicle: LJ80
 Posted: Wed Oct 28, 2009 4:23 am |
i made this box to store stuff yesterday 12mm ply screw & glue
(rough and bodgey) but it has a place for jerry and gives me a flat load area
all up cost of $120 including jerry
coilyzook
Joined: Sun Aug 23, 2009 11:30 pm Posts: 125 Location: central coast, NSW
 Posted: Wed Oct 28, 2009 4:31 am |
i like it, have you got any build pics, im thinking of doing a similar sort of thing
laurie
Vehicle: LJ80
 Posted: Wed Oct 28, 2009 12:26 pm |
no sorry
just take measurements to mr ply&wood (free cutting)
bag of screws, glue, contact adhesive,hinges, and a mat from carpet court
best thing is you can make it custom to your requirements.
do base first, then put all walls on, then fixed top pieces, hinged doors
finish with carpet and paint. contact is very messy. laurie
S13RR4
Joined: Sat Aug 22, 2009 11:30 pm Posts: 1072 Location: Sunshine Coast
 Posted: Wed Oct 28, 2009 2:54 pm |
coilyzook wrote: i like it, have you got any build pics, im thinking of doing a similar sort of thing
i did a similar thing in my softy, bit bigger though, check out this thread for some build-up pictures
http://www.auszookers.com/index.php?nam ... pic&t=7504
p.s. how do you go with accessing stuff when you've got stuff on top, is there a rear access door or anything???
_________________ My Rig --> Click WWW
lump_a_charcoal
Joined: Wed Feb 28, 2007 10:30 pm Posts: 4454 Location: Botany, NSW
Vehicle: MY2019 Jimny
 Posted: Wed Oct 28, 2009 3:19 pm |
Now you can take all that stuff out of your overhead console Laurie!
BlueSuzy
 Posted: Wed Oct 28, 2009 3:59 pm |
You might want to put one on the roof too for that trip to Kath!
laurie
Vehicle: LJ80
 Posted: Wed Oct 28, 2009 5:06 pm |
i left enough room at the front for the fridge
the only other heavy thing on top hopefully will be a water bottle
no rear door the cut out bit is to get the shovel out easier
the overhead console has auto eject too lazy to put it all back
rods are going on the inside of the roof
no way im going to put anything on the outside
only me and my boy going to katherine so room should not be a problem
really an esky and a change of clothes what else do ya need
ball
Joined: Wed Oct 22, 2008 10:30 pm Posts: 4673 Location: Katherine
 Posted: Wed Oct 28, 2009 5:21 pm |
laurie wrote: i left enough room at the front for the fridge the only other heavy thing on top hopefully will be a water bottle no rear door the cut out bit is to get the shovel out easier the overhead console has auto eject too lazy to put it all back rods are going on the inside of the roof no way im going to put anything on the outside only me and my boy going to katherine so room should not be a problem really an esky and a change of clothes what else do ya need
It's a suzuki, so a tool box would need to be included
laurie
Vehicle: LJ80
 Posted: Wed Oct 28, 2009 7:53 pm |
good idea ball i might find a broken down toyota
BUZOOKA
Joined: Sun Aug 30, 2009 11:30 pm Posts: 2659 Location: hobart tasmania
 Posted: Wed Nov 04, 2009 12:05 am |
laurie wrote: good idea ball i might find a broken down toyota
 classic
_________________ -indebt 4x4 club-
nav 32s n winch cust rear
laurie
Vehicle: LJ80
 Posted: Wed Nov 03, 2010 2:07 am |
i have added a rear shelf over the back door 320mm x 1040mm x 12mm ply
held in by ally right angle. with rear tie down points. cost about $10
ill use it next time i go camping for all the bulky stuff towels,tarps, coats ect
i reckon it would hold 10 to 15 kg off road easy.
now to redo the front one to hold both radio's and the clock.
