It is currently Sun Nov 15, 2026 3:26 am
Vehicle: 85 SJ413
Post Posted: Mon Nov 02, 2009 10:34 pm
I have made up a kit for fitting Vitara power steering to a RHD Sierra / Samurai using a machined wedge to align the steering box with the steering column.
I have tested the kit on my zook and it fits well, but I want to get a couple of kits fitted to other zuks to make sure I haven't missed anything before I make any more.
Does anyone want to be a test pilot?
The kit includes the CNC machined wedge and fasteners to mount the steering box, a mount to adapt the Vit power steering pump to the block and the required fasteners, and a spacer to move the radiator mounting bracket to clear the steering box.
Parts requred are the Vitara p/s box with pitman arm, pump, factory pump mounting bracket, hoses and reservoir.
Installation also requires a collapsible steering shaft and multi-rib pulleys from a 1600 (or a 1600 conversion!)
The box is mounted as far forward and down as possible to allow use of the stock Vitara pitman arm, and to give room to move the axle forward without the steering arms rubbing on each other.
Below is a pic of the kit:
Price is $200 AU, and I will ship these first ones free.
Ben
WWW.ZUKPARTS.COM - Quality Suzuki Off-road Parts
Post Posted: Mon Nov 02, 2009 10:44 pm
Nice work yet again mate..I will definately get one when I am ready for my conversion
Post Posted: Mon Nov 02, 2009 11:12 pm
if only you had this a month ago :cry: when i done my power steer.Instead i had to drill holes in chassis,crush tubes welded in,make new radiator mounts etc lol.
Top work looks like a good kit and for the $200 i know i wouldnt bother doing what i done again.
Post Posted: Tue Nov 03, 2009 12:27 am
Hey mate i'll take ya up on it. I've got all the stuff for a vit conversion sitting here ready to go (minus a resevoir).
I have a drop vitara to sierra pitman arm. do you think this would work ok?
if not i also have the vitara pitman arm. But have to ask, anything planned for adapting it to the sierra drag link?
Don't worry, It's only a suzi...
http://www.auszo
Post Posted: Tue Nov 03, 2009 12:31 am
One other question, i have a sierra V pulley to multi rib pulley (spider trax two in one type job). Will it be a prob if I have to modify the pump mounting bracket to line up the belts?
http://www.auszo
Vehicle: 85 SJ413
Post Posted: Tue Nov 03, 2009 12:50 am
The Vitara pitman arm has the same taper as the Sierra, so will bolt straight up to the drag link :wink:
The drop arm will also fit if it is to suit a vitara box, and will help keep the drag link flat and prevent bumpsteer if you have a bit of lift.
I haven't got a Spidertrax pulley to check, but it should line up I would think. I'm sure they would have designed it to line up with the 1600, so they could use the same pump mounting brackets on either engine in their kits. If not, it would be easy to slot the holes out to make it work anyway.
I'll PM you about getting a kit over to you.
Ben
Post Posted: Thu Nov 12, 2009 4:58 pm
another question.
are all the bolts high tensile?
If not should they be?
http://www.auszo
Vehicle: 85 SJ413
Post Posted: Thu Nov 12, 2009 5:20 pm
Yes, they are, and yes, they definately should be high tensile.
Ben
Vehicle: 85 SJ413
Post Posted: Sat Jan 09, 2010 11:59 am
OK, feedback from the first kits has been good, so I have more power steering kits available if anybody else wants one.
The price has gone up a little to $220 due to machining costs. Shipping is $30 to anywhere in Australia.
Some people were asking where the steering box is positioned with the kit. The wedge moves the box forward 20mm over the stock position, so it will also allow people to move the front axle 20mm further forward than normal before running into issues with the drag link and tie rod rubbing.
Ben
Post Posted: Sat Jan 09, 2010 6:17 pm
Do you know if this will work with a baleno PS pump?
Vehicle: 85 SJ413
Post Posted: Sat Jan 09, 2010 8:20 pm
The Baleno p/s pump is a little shorter than the Vitara pump. It has all the same mounting bolt positions, just a thinner pump section, so I suspect it would put out a fair bit less flow. From memory, the Baleno pump mount is also different, so may not bolt up to the pump mounting adaptor.
Ben
Post Posted: Sun Jan 10, 2010 6:42 pm
awesome, can't wait till i can buy a wedge, but also have you been working on the reverse adapter for a sierra motor to a vit box?
Post Posted: Sun Jan 10, 2010 6:59 pm
Great Kit! I have the wedge bracket on with full RUF and no contact between tie rod and drag link!!
Peter
Vehicle: 85 SJ413
Post Posted: Sun Jan 10, 2010 9:07 pm
Yep, thats on the list of things to do.
Ben
Post Posted: Sun Jan 10, 2010 9:16 pm
Ben
Let me know if you need any testing done for this one 8)
Post Posted: Sun Jan 10, 2010 10:07 pm
Ben
He wants a real challenge..I have a coily you can practice on :wink:
Post Posted: Sun Jan 10, 2010 11:59 pm
Rusho81 wrote:
Ben
bugger off i bought it up, i get first go :D :D
Post Posted: Sat Jan 30, 2010 11:40 pm
hi I am deaf I have 1.6 motor so need adaptor kit for fit my 1.3 gearbox when I pay u how long will flright to my place I am Brisbane
cheers Reynard
Vehicle: 85 SJ413
Post Posted: Sun Jan 31, 2010 1:21 am
Hey Reynard. You have a PM
Cheers,
Ben
Post Posted: Mon Apr 19, 2010 5:09 am
I've been looking for a PS kit to put a Sidekick/Tracker PS System on my Samurai when I came across yours. Not sure if this would work or if I should start looking for a Vitara PS System. Anyway, what would your cost be shipped to 23111 in the States. Thanks. Alan 8)
Vehicle: 85 SJ413
Post Posted: Mon Apr 19, 2010 8:26 pm
Vitaras and Sidekicks are the same for the most part, except for Sidekicks in the USA are left hand drive, while ours are right hand drive. For this reason my kit won't be much use to you, as its designed for rhd cars!
You can get similar setups for LHD from www.petroworks.com in the US
Ben
Post Posted: Thu May 06, 2010 12:10 pm
Hi Ben
Do you have any photos of the complete installation?
Users browsing this forum: No registered users and 13 guests
