It is currently Sat Sep 26, 2026 4:57 am
Post Posted: Thu Dec 10, 2009 9:14 pm
can i get to the output shaft bearing (the one that could cause play on the output shaft) without taking the gearbox out, or would i be mad even trying it.
Post Posted: Thu Dec 10, 2009 9:27 pm
No, because even though it's the rear bearing for the output, it's actually about halfway in the case and clamped between the upper and lower cases and retained by a ring in a groove. The only way to get it out is to separate the upper and lower halves of the case.
Post Posted: Thu Dec 10, 2009 10:20 pm
I have a disassembled box here Sam if you want to look at what's involved.
Post Posted: Fri Dec 11, 2009 12:47 am
okay no worries jas I'll let you know :)
Post Posted: Fri Dec 11, 2009 12:49 am
anyone know if any of the bearings from a leafy transfer case as the same as that bearing in question in the gearbox ? because i have a set of bearings and i whole transfer.
Post Posted: Fri Dec 11, 2009 2:46 am
They are damn close but I couldn't say for sure they are the same.
Post Posted: Fri Dec 11, 2009 3:30 am
As I mentioned, this bearing has a ring and groove to retain it. The ID of the bearing is pressed on to the output shaft and the ring retains the bearing (and therefore the shaft) in place. Without the ring locking into the groove on the bearing, the whole bearing and shaft float right on out the back of the box. You could use an ordinary bearing (I think it's either a 6206 or 6306), but it MUST have the groove. Ask CBC for the actual bearing number, they will likely have on in stock on the shelf.
But why are you only replacing one bearing in the box? Why not do 'em all?
Post Posted: Sun Dec 13, 2009 10:59 pm
there is a bearing with a retaining ring like that in the transfer case. thats why i was asking if they where by chance the same size.
i don't have an income and i am trying to hunt down a vibration, the only place i can see it coming from now is the output shaft.. so if i had a bearing i was just going to swap it out and see how i go.
Users browsing this forum: No registered users and 100 guests
