It is currently Sun Sep 27, 2026 6:33 am
Post Posted: Sun Dec 13, 2009 4:11 pm
I have a 85 drover tin top ute. Is that same as NT? ie difs springs transfer
IF so are wt springs same as nt ones?
Did a search for a post that listed the differences between nt and wt but too many results. May be a sticky is in order??
thanks
Post Posted: Sun Dec 13, 2009 4:13 pm
WT and NT and use the same springs.
Is that what you were asking?
Post Posted: Sun Dec 13, 2009 4:39 pm
You cleared up a small piece of the question Thanks.
85 drover ute: ? same rear springs as swb nt wt?
transfer flanges & ratio ?
dif flanges & ratio?
Brakes ?
tail sharfts jack sharft?
..anything else?
Vehicle: jimny
Post Posted: Sun Dec 13, 2009 4:52 pm
pretty sure the lwb and utes use a slightly heaver rear spring, but they are interchangeable
Post Posted: Sun Dec 13, 2009 5:08 pm
1 and 1.3 do not mix at all. flanges and splines....
Post Posted: Sun Dec 13, 2009 7:07 pm
The Drover is just a badge engineered 1.3 Sierra. The only differences are the headlights and grille and the badges/decals, all other parts are standard Sierra SJ413 (aka 1.3lt Sierra, aka SJ50 NT)
Post Posted: Sun Dec 13, 2009 7:28 pm
Thanks for that! so it is a rebadged NT ute.
That clears that up. nice one 303 zuke
Now I just have to get my head around NT WT compatibility and have some fun. Got a spare WT swb siting here for parts.
Thanks again
Post Posted: Sun Dec 13, 2009 7:40 pm
Drovers use a different universal joint than that of a sierra.
Sierra uni Joint is a TOYO part # RUJ 1795
Drover Uni Joint is a TOYO part # 902018
They are different.
Post Posted: Sun Dec 13, 2009 8:15 pm
They are different.
Thanks for that one have writen it down for future ref.
Post Posted: Sun Dec 13, 2009 8:18 pm
lol hope so, I bought sierra unis, they are sort of ok to use in an emergency, but they have an inner circlip, and the drovers have an outer circlip. Took me ages and ages to find the right ones.
Vehicle: Clown Car..
Post Posted: Sat Feb 06, 2010 11:39 pm
anyone got a pic of the inner/outer clips side by side? lil confuzed as to how they differ.. mayb my drover has been played with previously.. look to be an inner clip on mine but would love to confirm exactly what it is...
and shep.. good brain work ;) :lol:
Post Posted: Sun Feb 07, 2010 1:11 am
Drovers have NO tacho either. Instrument cluster is different.
Post Posted: Sun Feb 07, 2010 1:33 am
lol, wrong thread about the differences want ;) eh you got lotsa zooks.. go get a pic of the two kinds of uni for me.. inner and outer clip so can see what this actual difference is pls!?
Post Posted: Sun Feb 07, 2010 1:46 am
Will get some pics in the morning..
:D
Post Posted: Sun Feb 07, 2010 3:04 am
cheers bloke! will sink a Jack can for ya :)
Post Posted: Sun Feb 07, 2010 9:26 pm
How was that Jack Bryan?
NT jackshaft..... External clips..
WT front shaft.... External clips..
Drover rear shaft.... External clips..
I don't know what the deal is with these things but I have WT, NT AND Drover here and they all have the same style of uni fitted.
Post Posted: Mon Feb 08, 2010 12:47 am
Jack was great :) had more than one for ya fella :D
My jack shaft has a heap of wear where the red circle is, so I pulled out the spares box and found the WT one I stripped down.. going to take it down to a driveshaft place and just get em to match it up with the required uni, cbf stuffin round with it to be honest.. make it someone else's problem..
Is it possible to get the worn hole fixed or its pretty much binnable now?
i woulda used the WT shaft in its complete form, but the Xfer end is obviously set up with the smaller flange.. Bloody suzuki sizing! lol..
Post Posted: Mon Feb 08, 2010 3:29 pm
foolsp33d wrote:
My jack shaft has a heap of wear where the red circle is..........
It is possible to build up a worn ear on a yoke but not financially viable on a zook.
Flanges are easily swapped between NT and WT ... All you need is 2 uni's..
Use the uni to suit the shaft and then use the caps off the other to suit the flange.
1.3 caps are all 25mm and trunion shafts are all same so they swap about easily...
I don't know about 1.0 stuff.
Internal clips = RUJ 1795
External clips = RUJ 1783
Post Posted: Mon Feb 08, 2010 3:45 pm
ahh your a champion 33 :)
got a complete set of WT NT and 1.0's so somethin is bound to work!
NT Flange(female bit:lol:)from g/box|-- :Jackshaft from WT== :flange from NT to xfer =| so.. |--===| lol.. but im thinkin its going to require both inner and outer clips not 100% but thats what im guesstimating..
Post Posted: Mon Feb 08, 2010 5:11 pm
My drover lwb has external clips as well. Smaller bolt holes so am going to swap some bits over to put the wt diffs in. Using wt transfer so will use wt flanges and hopefully the joints can be swapped as suggested then the 0nly original bit will be the rear nt lwb shaft.
98 GV
Users browsing this forum: No registered users and 1009 guests
