It is currently Mon Sep 21, 2026 9:59 am
Post Posted: Tue Dec 22, 2009 3:01 am
I'm in the process of changing my clutch. should I change rear main, even if it looks ok, no leaks? Is it jst removing old one with screwdriver and putting new one? (flyweel is off, got it machined) I guess I need to drain oil from engine, it will come out once I take the seal out, right?
speaking about clutch change, nothing is easy. I had heavy duty one, To put it in I removed engine. done 10000km, looks still like barly used. I broke 3 clutch cables (Royce knows something about it as I found out on one of the posts) and decided to get standard clutch. I have vit box so its bigger anyway. I don't know who done my conversion (previous owner), but they must have put vit gearbox and than engine. there is no way that bloody box would come out. I cut out with my friend grinder crossmember and got bloody box out. I have custom gearbox rear bracket, which uses sierra g-box mount and I thought I could use high clearance crossmember, I got from states (been assured it would work). no way, I have to make different crossmember tomorrow by myself. That one from states is now for sale. nothings ever easy.
Vehicle: lj81 stockman
Post Posted: Tue Dec 22, 2009 3:10 am
yes
the wobble rocks
Post Posted: Tue Dec 22, 2009 3:11 am
X2
Post Posted: Tue Dec 22, 2009 3:12 am
You prob dont need to with that low kms, on the other hand, they are dirt cheap and its often hard to tell if they are leaking- but 10,000kms, its still brand new!
Post Posted: Tue Dec 22, 2009 3:16 am
Definately do rear main!! I was lazy and didn't do it when I did the clutch.. and I paid for it the next outing.
BTW I'm pretty sure I've met you before... I recognise that truck... I think you were at suzispares?
Post Posted: Tue Dec 22, 2009 4:13 am
yep
Vehicle: LJ80
Post Posted: Tue Dec 22, 2009 4:21 am
for sure. the perfect time is right now
Post Posted: Tue Dec 22, 2009 4:26 am
yes always do it. Its only $8. Have a look at your trans input shaft seal while your there.
Because of how my exaust is with my extracters I can't remove my gearbox without removing my extracters, I had a clutch go out last week and simply took all the bolts off the box and slipped it back as far as it would go held it up using a strap going through the timing hole at the top of the bellhousing and up to the coil bracket to hold it up.
Hard to explain but it worked.
Post Posted: Tue Dec 22, 2009 12:09 pm
Always do youre rear main when you have the gbox out. Dont go cheap either, use genuine seals, theyre only like $30. Ive found from personal experience that aftermarket seals are shit.
Post Posted: Tue Dec 22, 2009 12:29 pm
Only if you get asian aftermarket. My German ones have nevr leaked after replacing the factory ones.
Post Posted: Tue Dec 22, 2009 12:49 pm
if tis done 10000km, I reckon the risk of fitting it wrong is greater than the extra 10000km km's before a new one will leak
if you dont know how long its been in replace it
if the engine has been sitting it shouldnt drop and oil, at best it will be enough to get on your shirt a bit if you dont get out the way :)
Vehicle: MY2019 Jimny
Post Posted: Tue Dec 22, 2009 1:31 pm
Hey Chris, I remember back last year your clutch went and you had the same issues...
Sounds like if you can, modify stuff so you can remove the box without removing the engine, while you have the chance!
Remember I have a welder here if you need it...
Good luck mate.
Post Posted: Tue Dec 22, 2009 2:12 pm
I don't know when the rear main was changed last time. When I changed clutch lst time for heavy duty one, I did it at my mates place, he wasn't very keen to change rear main so I didn't. Now is the good time. Technial question, do I need to remove oil seal housing to change seal? Service manual shows that Or maybe it is when you assamble whole engine. I guess ones I remove rear oil seal housing I would need new gasket for it. or did I get it all wrong?
Post Posted: Tue Dec 22, 2009 2:27 pm
To remove oil seal housing you need to remove sump first. Not necessary if you are just replacing seal.
Post Posted: Tue Dec 22, 2009 2:41 pm
Replace the spigit Bearing also
Steve W
Post Posted: Tue Dec 22, 2009 4:03 pm
yes for sure
Post Posted: Tue Dec 22, 2009 5:12 pm
As sure as shit, if you dont do it you know what will happen.....
A week later there will be oil on the driveway... :cry:
Looking for LJ80 bits:
1Lt NT front diff for disc
Post Posted: Tue Dec 22, 2009 11:10 pm
X2
Post Posted: Tue Dec 22, 2009 11:12 pm
Which is what happened with bleedin aftermarket seals.
Post Posted: Wed Dec 23, 2009 3:22 am
I was few times at suzispares, so it could be me.
Post Posted: Wed Dec 23, 2009 5:16 am
You would recognise his accent!
Post Posted: Wed Dec 23, 2009 12:55 pm
X2
X3
leave a good low km seal alone.
Users browsing this forum: No registered users and 117 guests
