It is currently Fri Nov 13, 2026 11:52 am
Post Posted: Fri Jan 08, 2010 4:51 pm
who has put the newer model steel gv diff into a vitara?
after asking for the older model diff i was sent the newer model and i cant be stuffed waiting another close on 2 months for the other to be sent to me im only guessing 2 months tooks them about that last time
would it work if i made a custom braket for the cross member mount as from what i understood it was the mount that hit the sump is this right?
or would it work if i do a diff drop ie cut the cross member top section and lower the diff into it?
its into my 2L v6 vitara
thanks for any help people can give im hoping not to mod the sump as i dont have a tig to weld it but do have a mig so can mod the cross member
Post Posted: Fri Jan 08, 2010 5:49 pm
mike.knew has done this, after a lot of head aches he did get it in there with a modified sump & the late model diff bracket. not sure if it's in his build up thread or in tech, i'll have a look & see what i can find.
Post Posted: Fri Jan 08, 2010 5:53 pm
i found one thread from him and all it said was the braket hit id love to get the other diff but unless i find one local and keep the other as a spare dont think this will be happening
Vehicle: SV420
Post Posted: Sat Jan 09, 2010 2:34 am
G'day tombutt, on outers a bloke fitted the later model type gv steel front diff and carrier to his grand vitara (about a 98-99 model) and he didn't have to do any mods to his sump according his build thread
http://www.outerlimits4x4.com/ftopic144 ... 74ac2b0279
so with you having a V6 and a different sump ... you might be lucky :lol:
The problem I had with my J20A SWB Vitara is the part I have coloured here red what was hitting the sump.
The guys at ARB Port Macquarie called once they noticed the problem and after having a look myself, the fix we decided was to modify the sump and push part of it back about 25 mm in with an oil press and in the end it looked quiet good :D until the sump was put back on and it leak around where a gasket would go :cry: (no gasket used on J20A Vit Sump just some sort of goo sh!t). I have uploaded a picture for you that shows the modified sump.
Using sockets between the block and the sump, around the bolts, the guys slowly squeezed the sump back to square and using a straight edge checking where the sump needed to bend, apparently it is bit of a ralley car trick - not really sure what that means :lol: This fixed the leaking sump issue 8)
Another option was to modify the bracket or make a custom one but I had to make a decision whilst the car was on the hoist quickly and modify the sump at first looked to be the easiest and best.
A diff drop I am guessing would of been another option to give you the extra clearance so good idea.
Here is a picture Steuy has on his build thread of someone elses car I think that shows where the member had to be modified.
Vehicle: SV420
Post Posted: Sat Jan 09, 2010 2:44 am
tombutt wrote:
would it work if i made a custom bracket for the cross member mount as from what i understood it was the mount that hit the sump is this right?
Actually this triggered a memory and I think it was more than just the mount hitting, it was the carrier (third member) hitting as well.
Post Posted: Sat Jan 09, 2010 4:44 am
fark me mike, i didn't realise they made that much of a dent!!!
Post Posted: Sat Jan 09, 2010 7:08 pm
any one have pictures of the 2L 4 banger sump i just wanted to compare the two looking at pictures thats ive found that havnt been to great shouldnt be too much of a problem
Post Posted: Mon Jan 11, 2010 2:02 am
well after todays measuring and going hmmm i think the diff housing will fit as is i think the v6 sump gives enough clearance just gotta get my lazy arse mate to do my ratio swap now or take it to a shop
Vehicle: SV420
Post Posted: Mon Jan 11, 2010 5:53 am
yeah i reckon there is space for an oil cooler
Post Posted: Sun Sep 01, 2013 2:24 pm
stem1 wrote:
The "outers" link and the sump photo both return 404 not found errors. Is there another way?
i've re uploaded the image below.
Users browsing this forum: No registered users and 61 guests
