It is currently Tue Oct 20, 2026 2:36 pm
Post Posted: Sat Jan 09, 2010 10:06 pm
Hey Guys, just started up my rebuilt engine in the zook for the first time runs very nicely. But after getting it running well, i went to take it for a drive and when i started it i got a high pitched squeal coming from somewhere. Thought it might have been the timing belt rubbing but thats fine. I also put a new clutch and gearbox bearings in while the engine was out, i did a quick search and sounds like it could be the new clutch, however it whines when you engage or disengage the clutch so i'm not sure, what it is. Any Ideas
Thanks Clem
Post Posted: Sun Jan 10, 2010 12:22 am
check your gearbox oil
Post Posted: Sun Jan 10, 2010 2:41 am
just a thought but check that the cam tunnels are square to the head , it is not unusual for cams to squeal in the carrier if the head is not straight
growing old is nature, growing up is choice.
Post Posted: Sun Jan 10, 2010 3:32 am
Thanks for the replies think i've found it, i think the seal has gone on one of the linkages for the butterlfy valve, as the squeal doesn't change with the revs and if you play round with the rods it changes the squeal.
mightymouse the cam tunnels cant really change as the head is all one piece so they cant be moved, i think thats what you mean anyway.
Post Posted: Sun Jan 10, 2010 3:52 am
they will if the head is warped.
Post Posted: Sun Jan 10, 2010 3:56 am
oh yeah i see what you mean now
Users browsing this forum: Google [Bot] and 155 guests
