It is currently Tue Oct 20, 2026 2:41 am
Post Posted: Sat Jan 09, 2010 6:15 pm
I replaced seals in the dizzy. It's fine now, but I've noticed that sump leaks a bit. Do I need to buy a gasket and put gasket sump sealant or jst sump sealant only. Should I do anything (clean) with the oil strainer while I have sump off the engine? What do you advise?
Cheers Chris
Post Posted: Sat Jan 09, 2010 8:20 pm
hmm, just tighten the bolt's and see how she goes, if it still leaks buy a $10gasket from repco and she will be right and not leak at all
for the record thats fairly confusing what you wrote, but at least it was all spelt correct :lol:
Post Posted: Sat Jan 09, 2010 10:05 pm
You can use either. Personally i use coon
Post Posted: Sun Jan 10, 2010 12:22 am
isn't that a cheese :lol:
Post Posted: Sun Jan 10, 2010 3:39 am
yea that bit about dizzy might be confusing. It leaked from dizzy housing before, so I didn't know that sump leaks too. thanks.
and what means coon?
Post Posted: Sun Jan 10, 2010 3:50 am
'if' the sump is leaking from the bottom rear than its more than likely a rear main. just use silicone, suzuki never had a gasket for the sump.
Vehicle: Clown Car..
Post Posted: Sun Jan 10, 2010 3:56 am
Silly-coon....
edit: :roll: :roll: :roll: sorry guys... but tried putting 'coon' into google lately!? then clickin images.... ?
might want to edit your posts in accordingly to :oops:
my appologize
Post Posted: Sun Jan 10, 2010 3:59 am
:wink:
Peter
Vehicle: Jeep
Post Posted: Sun Jan 10, 2010 4:59 am
Thankyou ! :wink: :D
Post Posted: Sun Jan 10, 2010 2:34 pm
Cheers Chris
as they said i would use silicone to seal it...
while it is out it wouldn't hurt to clean the oil pick up. as your already in there.
Post Posted: Mon Jan 11, 2010 3:47 am
I changed clutch and rear main two weeks ago. It looks like sump is leaking in few places, not only at rear, I was wondering if that oil was because of the dizzy leak or sump leak, once I replaced dizzy seals and rear main (didn't leak) it means its sump. Anyway I pull it apart, use sillicon and will see if its only this or something else.
I was confused, because manual doesn't show any gasket, but you can buy one.
cheers
Post Posted: Mon Jan 11, 2010 4:51 am
As others have said, just scrape the bottom surface of the block with a razor blade to remove old sealant and do the same with the sump. Then apply a few mm thick bead of silicon gasket sealant (must be automotive type, not houshold shit :D ) and let it sit for a few mins. Then bolts it up firm.
And just a word of advise, trust the sealant. Don't go swinging off those little bolts because it doesn't take much to snap them off in the block. :x
Peter
Users browsing this forum: Google [Bot] and 168 guests
