Joined: Sun Dec 28, 2008 10:30 pm Posts: 3712 Location: melb
Posted: Wed Jan 20, 2010 2:12 am
good to hear mate
you will be better off in the long run
on a side not I picked up a set of celica gt4 seats for mine today (fuck I hope they fit) theyre comfy as
Actually, I might pick your brain while you're here. What would you recommend to reinforce the top and bottom of the floor? Do you reckon some thick flat bar top and bottom would do the trick?
Posted: Wed Jan 20, 2010 2:25 am
if height is an issue id look at maybe recessing something like 57 x 35 though the floor picking up the sides as well and with a folded 90 deg lip on floor pan spot welded to rhs and the seam sealed.
you really need the depth to give it strength and you be suprised how much force is on that rail just with you sitting on the seat hitting a bump.
you maybe able to put a beam tpo and bottom but I cant picture the underside. Ill have a look at mine and get back to you.
Users browsing this forum: No registered users and 174 guests
