It is currently Tue Sep 01, 2026 10:18 pm
Post Posted: Mon Jan 25, 2010 1:18 am
Got a mini-project in mind and i need a pair of front or rear WT flares, dented is fine depending on which parts are still usable.
Daniel -
Post Posted: Mon Jan 25, 2010 1:54 am
Got a set of dented ones or good ones mate let me know if you want them
TWIN LOCK IT & JUST DRIVE!
Post Posted: Mon Jan 25, 2010 2:27 am
Daniel - 0421 848 827
Located Brisbane Southside
What are you up to??? :? :?
There is only 2 diffrent flare's, the lh front is the same as the rh rear, & the lh rear is the same as the rh front.. :wink:
Post Posted: Mon Jan 25, 2010 2:32 am
ill show you once its done steve.... yes i am taking pictures.
Post Posted: Mon Jan 25, 2010 2:34 am
I like pic's!!! :P :P :roll:
Post Posted: Mon Jan 25, 2010 3:07 am
Sounds like some stretched big flares coming up for a virtual lift?????????
Post Posted: Mon Jan 25, 2010 4:20 am
mmm not really, just need to extend the rear flares down to cover where the stocko plastic bit is sposed to be on a wt, was going to cut up some dented flares and weld em on.
Post Posted: Mon Jan 25, 2010 10:26 pm
The flare's you got of Jas had tyre tread hanging in tha place of bar end's, worked as mud flap's to. 8O :roll:
Post Posted: Mon Jan 25, 2010 10:36 pm
I had the same idea, it'll be interesting to see how it turns out.
Users browsing this forum: No registered users and 6 guests
