It is currently Tue Nov 03, 2026 3:49 pm
Post Posted: Tue Feb 02, 2010 1:12 am
Is there any body out there that can make me this out of steel or a suitably strong material. all its purpose is to lift my rear bar up 2 inches without havving to weld any alloy. i have all the measurements worked out.
Post Posted: Tue Feb 02, 2010 1:14 am
i am sure anyone can make that very easy
navara on 33s. hopfully rear air locker soon
Post Posted: Tue Feb 02, 2010 1:19 am
yeh i can to but was looking for something more precice than that.
Post Posted: Tue Feb 02, 2010 2:32 am
Get me the dimensions, and I'll laser cut and CNC press it for you. I'll need a week or so to get the order through tho. :wink:
Post Posted: Tue Feb 02, 2010 1:32 pm
That sounds like what I'm after.what is a Cnc press? How much am I looking at for two?
Post Posted: Tue Feb 02, 2010 5:41 pm
Computer controlled machinery...it will bend, cut, drill, mill etc to the width of a pubic hair.
Post Posted: Tue Feb 02, 2010 6:01 pm
a cnc press will only bend. its computer controled and is very accurate. great for production where eveything needs to be the same
but you can get cnc mills, dill, lathe, plasma cutters, laser cutters, water jets, you name it they got it in cnc basicly
Post Posted: Tue Feb 02, 2010 6:21 pm
They will come out looking the buisness bigrig... :P
Post Posted: Sun Feb 07, 2010 1:02 am
please delete. not needed
Post Posted: Sun Feb 07, 2010 8:27 pm
This is where you say how YOU made it. "I made it and fabrication"
If you wanted it. It should go in the "wanted" section...
Post Posted: Sun Feb 07, 2010 10:35 pm
Delete
Post Posted: Sun Feb 07, 2010 11:55 pm
wtf?
Post Posted: Mon Feb 08, 2010 3:59 am
I call BS, there is no actual fab here!
Only a vague paint pic and an explanation of the various CNC machines.
Explain why these are no longer required at th least. (be helpful)
I'm very bored and slightly interested...
Post Posted: Tue Feb 09, 2010 1:39 am
hahah sorry mate. These are no longer needed because i used different brackets which was alot easier. i needed the original brackets because there wasnt enough room to move inside the bar. i measured and thought and decided to put it on the bottom because it was exact measurents. i did this, instead of this. if you get my bad paint.
Post Posted: Tue Feb 09, 2010 1:41 am
I finally got sick of trying to organise someone to weld my bar for me so bamm. I bought some steel, drilled some holes and cut some bits. i made two brackets out of 8mm plate steel (a bit overboard i think). Measured the difference and bolted the plate to the bar and the bar to the chassis.
Description:
Filesize: 59.87 KB
Viewed: 75 Time(s)
Description:
Filesize: 79.13 KB
Viewed: 75 Time(s)
Description:
Filesize: 74.39 KB
Viewed: 75 Time(s)
1997 Sierra, daily driver, weekend warrior
Back to top
joseph
azcrew
Posted: Sat Feb 06, 2010 7:21 am Post subject: Re: my 1997 sierra (bigrig) pics of uhf install
Stekky is gunna love that middle pic mate but where is the pic of the bar fitted???????
JOES4B www.auszookers.com/ind...pic&t=7632
My old vitara R.I.P www.auszookers.com/ind...pic&t=5739
Bullant www.auszookers.com/ind...pic&t=6153
Back to top
bigrig91
Rock Stacker
Posted: Sat Feb 06, 2010 7:22 am Post subject: Re: my 1997 sierra (bigrig) pics of uhf install
more pics.......
Description:
Filesize: 137.01 KB
Viewed: 65 Time(s)
Description:
Filesize: 117.1 KB
Viewed: 65 Time(s)
Description:
Filesize: 66.79 KB
Viewed: 65 Time(s)
Users browsing this forum: No registered users and 16 guests
