can some one tell me the cv joint closest to the hub on the passenger side is there a circlip/snap ring to hold the actual drive shaft into the inner ball race off the cv.
when I removed mine the shaft pulled straight out.. I cleaned it out and found no evidence of a ring but a provision for it on the shaft .
referenced the manual and couldn't come up with a decent diagram.
yeah thought so..just wanted to check
because the inner joint allows for movement it seemed strange the shaft in the outer joint had no method of retention
Users browsing this forum: Google [Bot] and 157 guests
