It is currently Wed Sep 30, 2026 6:32 pm
Post new topic Reply to topic  [ 35 posts ]  Go to page 1, 2  Next
Poll: 00' Jimny for conversion/s to a Rare 88.5 Sierra Lwb Wt
M13A Auto and jimny transfer, Sierra chassis, diffs 12%  12%  [ 3 ]
M13A Auto, Sierra transfer, diffs (vss headaches) 23%  23%  [ 6 ]
Whole Jimny drivetrain, chassis extension for wheelbase. With lwb body on top modded for new chassis = Coils all round. Less engineering/physics dramas. 27%  27%  [ 7 ]
Get rid of Jimny, Keep Lwb Wt all original 38%  38%  [ 10 ]
Total votes : 26
Post Posted: Sun Feb 14, 2010 2:47 am
I now have a whole Jimny, for a conversion. As the body is too damaged to repair and fixing it is too much of another project with too little space. I have too many cars.
By researching. There seems to be problems with the M13a wiring into a sierra because of the imoboliser.. Then there are more problems if you dont use the Jimny transfer for vss. I am sure i can win though :lol:
So again, I'm indecisive. I need some help.
My Lwb Wt Is being rebuilt/Restored to perfect condition. All original height. No lift. And not to be used offroad much.(only slight dirt tracks, mainly touring). I want it to look original on the outside, but dont mind improvements for acceleration, handling and safety.
I want it to be smooth, reliable with no problems ever(if thats possible)
I am also unsure if the original number matching 1324cc actually runs/goes? if i keep original, it may need a rebuild, I dont have the money. M13a does not need a rebuild.
The last option depends on how well it drives. If it drives rougher then my swb. I will sell it. I am over rough cars, 1 is enough.
Post Posted: Sun Feb 14, 2010 2:51 am
could ya make a lwb jimny ute with it that would be cool
where is the damage?
having the m13a and auto in the lwb would be nice if you dont have plans for off road you probably wont need gearing so you could use the jimny transfer aswell.
Post Posted: Sun Feb 14, 2010 2:55 am
Yes she will be kept stock looking.. I already have a monster swb for serious stuff. (Still growing, bundera's after lwb build)
I love the look and seeing stock Lwb's. They are just cool. So owning one, even a super smooth jimny coil one, will be better then my smooth 77 rolla.
The damage on the jimny is pass door, pillar, quarter. So really, a full body swap if to re rego. it would make it a cheap Jimny. But too many projects. 2 is enough 8O
Post Posted: Sun Feb 14, 2010 3:02 am
yeah fair enough a coiled lwb with efi and auto sounds very comfy and nice to drive. does it have p/s too just too? it would be a good zook to daily drive
i vote the stretched chassis with lwb body if possible
Post Posted: Sun Feb 14, 2010 3:07 am
Has ps.
It will be easy to stretch the wheelbase over midsection, extra box section and long support/fish plates, and modify mounts/body to suit.
It's just the case of is it "Engineerable" :?
If it is, thats my best option. I will have to ring an engineer monday. Possibly Athol.
Post Posted: Sun Feb 14, 2010 3:14 am
If it can't be done that way go with the Jim running gear in the lwb
Post Posted: Sun Feb 14, 2010 3:17 am
Yeah. Thats my second best option.
She was going to be all original until this little jim popped up. :lol:
Post Posted: Sun Feb 14, 2010 3:24 am
Then you'll wanna wheel it and put 33's on with lockers lol the Sierra bug always bites hard
Post Posted: Sun Feb 14, 2010 3:26 am
You missed my swb build didn't you..Check my sigline.
Post Posted: Sun Feb 14, 2010 3:33 am
Nah I've read it start to finish lol I have wanted to have the sane spring setup in the rear as yours
Post Posted: Sun Feb 14, 2010 3:35 am
:lol: Abit of work.
Anywho, common people! Need your opinions!!
Post Posted: Sun Feb 14, 2010 5:29 am
:lol: Abit of work.
send the jim to me so I can make a lwb hard top, you keep your lwb & fix it.
:roll: simple!!! :roll:
Post Posted: Sun Feb 14, 2010 5:37 am
LWB jimny running gear under the LWB sierra tub....
or
send it to stekky land so he can build a LWB jimny
Post Posted: Sun Feb 14, 2010 6:27 am
I reckon the M13a is a smoldering piece of shit. Yeah its smooth running, and yeah its better than a carby 1.3, but a G16 MPFI swap is 10 times easier than M series into sierra, and has more power and heaps more torque.
Keep restoring the sierra, leave it stock, piss the jimny shit off, and buy a low km G16B jap import front cut and enjoy it.
JMO
Pete
Post Posted: Sun Feb 14, 2010 6:31 am
keep the LWB looking like new on the outside and put all the Jim gear under it. As you said you are going ot use it as a daily. You wont need gears or anything. It will be good cruisen with a new nice running smooth EFI and Auto in a classy old looking zook.
Post Posted: Sun Feb 14, 2010 6:49 am
Have you seen this conversion dave?
For starters, you will need to remake your tranny tunnel unless you do a body lift.
Secondly, the jim transfer case is chain driven. WTF would you want this?
Next problem is the diff swap. WT diffs are heaps better than jimny. No stupid wheel bearing, no hub conversions needed etc etc.
But the biggest problem is getting it running and keeping it reliable. The wiring is nothing short of a nightmare. It helps that the ECU, transponder unit and key are all from the same vehicle in this case, but the wiring is very complex compared to say a G16B.
Not worth the effort IMO. Not for a shitty 60kw.
Post Posted: Sun Feb 14, 2010 11:43 am
well if you can get in contact with saam he did a m13a swap in his coily and he might be able to tell you a bit more about it
Post Posted: Sun Feb 14, 2010 12:15 pm
keep the lwb shell and chassis rails, chuck the rest and replace with jimny :)
yes its too much work
yes it wont do anything better than a jimny
yes it will cost a shitload to make it all spot on
but none of that matters cause it will be cool and being able to get a real jimny sierra badge and sticking it on the side will be worth every last headache building it
Post Posted: Sun Feb 14, 2010 12:20 pm
Honestly, if you don't want the hassle, stick to the standard driveline. You've seen how well mine runs, and it drives fine on the road although I'll admit a little extra poke would be nice. Nothing that I don't think a decent exhaust system, Vitara clutch fan, and mild camshaft won't fix.
If you're going the m13a route though, let me know. I'd be happy to lend a hand in conversion (I like rooting around with wiring) :D
Post Posted: Sun Feb 14, 2010 1:26 pm
Keep the LWB standard.
Sell the jimny parts off or get another body for it then sell the whole jimny off.
Or buy another good jimny and keep all your other jimny parts for when it fails. :P
255 characters
Post Posted: Sun Feb 14, 2010 2:37 pm
coils on WT diffs with an injected, auto, surrounded by lwb.... my vote anyway...
Post Posted: Sun Feb 14, 2010 2:51 pm
No he didn't. He fitted the G13BB jimny motor.
Post Posted: Sun Feb 14, 2010 4:45 pm
I'm still thinking Jimny chassis with all the driveline. It just sounds so simple.
Why is it going to be so hard to wire, I have the whole harness and everything, it will all go into the lwb. There will be hardly any sierra lwb wiring left!
If the tunnel needs widening for the auto..I have a Jimny tunnel here! I'm already cutting the rust out of the lwb next to the tunnel. So it isnt going to be that hard..
Transfer, Who cares? Whats the matter with a jimny transfer if it is never going to be modded. Plenty of jimnys out there modded. With the jimny transfer.
What jimny rear diff bearing are you talking about? I have some wt diffs here if the jimnys are a pain. (I know the Jim's are weaker)
The m13a with auto goes good. I drove her home. 30min drive. Yes the g16b is better, But I already own one! Drive a 3k 1166cc rolla for a daily. Now thats a power house..
Then later, if i still want more power. I will go m18.
The Jimny ride is compareable to an 05 corolla. Now thats an improvement.
Post Posted: Sun Feb 14, 2010 5:06 pm
as a mod chassis extensions are pretty poorly looked apon, too hard to test its strong
welding in the suspension mounts to a sierra chassis on the other hand would be a lot better
Post Posted: Sun Feb 14, 2010 5:10 pm
Ah ok. I will be ringing an engineer.
People do extensions all the time on 1 end or even both ends.. Why not in the middle? We'll see.
Post Posted: Sun Feb 14, 2010 5:18 pm
Then you had better find a good supply of autos, because they are not renound for their strength.
Pete
Post Posted: Sun Feb 14, 2010 5:20 pm
:lol:
I'm sure i will be happy with the m13a.
Post Posted: Sun Feb 14, 2010 5:24 pm
tim your not listening to anyones advice.
Post Posted: Sun Feb 14, 2010 5:38 pm
Advice?
They all say don't do this dont do that. But no reasons behind them to back them up!
I posted a heap of questions, Since then, Fatzook has not answered questions on his past advice...
I do not care how much work is involved. I will be doing all the work. Both cars have no rego. So its an endless time limit to get things right the 1st time.
Post Posted: Sun Feb 14, 2010 6:11 pm
resell the jimny. you could easyly make 3x as much as you got it for or even part it out could get heaps more
put that money into the lwb
navara on 33s. hopfully rear air locker soon
Users browsing this forum: No registered users and 144 guests
