It is currently Fri Nov 13, 2026 5:23 pm
Post Posted: Sat Feb 20, 2010 7:26 pm
Hey all!
Quite a few questions on here about the VSS which is required on the seirra speedo head for G16 EFI conversions I decided to investigate and make one up considering some prices they were selling for 8O . Armed with a spare sierra speedo cluster (thanks to Jas and the Sunny coast wreckers) and a bottle of bundy red I pulled it apart to figure out its mistery.
Speedo unit removed from the dash cluster, pretty easy only a few screws here and there:
Take the speedo unit apart carefully has a very small calibrated wound spring and other small bits. Only 2 screws are holding it together, you can see these in the above pics and this is what your left with. It a magnetic drive disk! Pretty neat and simple. Has 4 magentic poles built into the material North,south,north,south.
Tried measuring the pulses with a hall effect sensor that had a built in schmitt trigger. That worked but gave me 2 pluses per rev. Jas with his vit cluster clarified that it should have 4 pluses per rev. No problemo. Went out to jaycar, bought a reed switch and mounted it to a piece of vero board.
Placed it under the magnetic disk and presto 4 pulses per rev!!
This is as far as I've got only thing to do now is mount it to the head and put the speedo back together. Install in cluster with a wire to the VSS input to the computer, the other to ground. 8)
Dan
Post Posted: Sat Feb 20, 2010 7:36 pm
Good work Dan. :wink: :D
Post Posted: Sat Feb 20, 2010 7:42 pm
nice!
Post Posted: Sat Feb 20, 2010 8:54 pm
you know what i like about this. its one of those things most people would not bother doing, but u sat down and thought about it, and also knew enough to make it all work. and how simple is it, and i bet it saved u a heap of $$ and stress..
good work..
Post Posted: Sat Feb 20, 2010 9:30 pm
I can't wait till the royalty cheques start rolling in! :rofl:
Post Posted: Sat Feb 20, 2010 9:51 pm
8O wow your a smart little bugger good stuff matey
Post Posted: Sat Feb 20, 2010 11:01 pm
that is simply awesome 8O
auszookers brings the tech!!!
Post Posted: Sat Feb 20, 2010 11:31 pm
I know 3/5's of SFA when it comes to these things...I assume this will replace the need to find a Vit cluster and adapt to the sierra cluster? Will you be producing these for fellow zookers??
Sorry for the silly question :oops:
Vehicle: WR250F/Jeep XJ
Post Posted: Sat Feb 20, 2010 11:48 pm
Have a look in the speedo unit of an EFI Toyota starlet dash cluster...you might be pleasently surpirsed what you find in there.... :D
oh nice work on the tech as well...I don't know if its just me but both here and outers has been seriously lacking some decent tech in the last few months....
Post Posted: Sun Feb 21, 2010 7:08 am
Thanks for the replies guys. Yea just thought it would be handy to try and explain how it works and what it looks like to fellow zookers. I hate 'black box' things ie don't know what they are doing.
Correct!! This way you wont need to hunt around for a vit cluster and tear that dash apart also. Can adapt it straight to the sierra speedo unit. Did up the thread so some could sort of follow it to make up there own. Guess I could make some up and install it if given the dash cluster.
At the mo its still a proto so I will test it out first, then neaten it up a bit.
Dan (Bring back the TECH!!) :wink:
Post Posted: Sun Feb 21, 2010 8:08 pm
Ok didn't like the board I started with (wasnt up to my standards of neatness) so made another one. Fits alot better now and looks the part!
New board custom ground to fit the speedo head snuggly.
Board fitted to the magnet disk assembly and into cluster
Connections to the cluster wiring. Top screw is ground and has been grounded through the tracks underneth it. Bottom screw has the VSS conenction which will go to the comp via an earth lug style terminal.
Now to install it into my speedo and test :D
Dan
Post Posted: Tue Feb 23, 2010 1:53 am
your build and all the nifty stuff you come up with just keeps me amazed. Nice :D
Post Posted: Tue Feb 23, 2010 2:55 am
The tide mark in the cluster above reminds me to drill some holes in mine to let the water out when I Gerni the interior....
Post Posted: Tue Feb 23, 2010 3:58 am
Well it works perfect!!! No more crappy engine check light!!! The comp definatly seemed to be in some sort of limp mode before the VSS. Idle has dropped and smoothened out, pickup at speed is much better!! Be interesting to see if it changed the ecomomy much.
Dan
Vehicle: 97 SV420/627 SWB Vitara
Post Posted: Tue Feb 23, 2010 4:55 am
That is very nicely done. I'm sure your efforts will go on to help many.
This is the sort of stuff I enjoy tinkering with too. What kind of background do you have to have an understanding? Is it a hobby or have you had some professional training of sort? I studied electrical engineering at uni (which just seems to mean I'm the chosen one in the family to tune in the oldies prehistoric TV and VCR). As i'm sure you can appreciate, Jaycar is a bit of a nerds toy shop heaven!
And I totally understand your black box reference.
Lifted, Locked & Loud. Expensive Little Toy...
Post Posted: Tue Feb 23, 2010 5:02 am
Thanks a million JrZook!!
Post Posted: Sat Feb 27, 2010 2:07 am
good work
 Profile YIM
Post Posted: Sat Feb 27, 2010 3:38 am
Where are you located and what would you be asking to do this conversion? I have a vit speedo in mine, but would prefer your method.
Pete
Post Posted: Sun Feb 28, 2010 3:00 am
Pete
Pete, check your email.
Vehicle: SJ80
Post Posted: Wed Mar 03, 2010 12:20 am
So Dan, it's been a while. If the car's been on the road a bit to test it, how much do you reckon the fuel economy and power has improved?
Post Posted: Wed Mar 03, 2010 1:10 am
Hahah settle down!! Haven't done much k's on it yet to comment on fuel ecomony. Seems to go alright and seems to have more poke around the 100KPH mark! That said the idle has also dropped a few hundred and is smoother most likely due to teh comp not running in some sort of limp mode. I will get back to ya on the economy!!
Dan :D
Vehicle: SJ80
Post Posted: Wed Mar 03, 2010 1:47 am
Cool, I'm mainly interested in increasing the economy to get better range. I know that mine doesn't have a VSS, and that the exhaust pipe is black as. As I understand it, (someone correct me if I'm wrong), one function of the VSS is to lean out the engine with forward speed. I'm gonna give your VSS a go and I'm curious as to how much my engine is currently choking itself.
By the way, thanks for putting up an excellent solution that I for one wasn't aware of.
Post Posted: Thu Mar 18, 2010 4:55 pm
No problems!
So what are the specs on your car? My last fill up with the VSS I got 250k's out of 27.5L. Sierra running 30's WT diff ratios and 4.9:1case. Now this 250ks was exactly what the tripmeter read no adjustments. With my proto speedo/odometer project ive found that the tripmeter is out about 15% with these tires. So that equates to 287.5k's/27.5l or 10.5ks/l. This was all stop/start town driving.
What sort of economy do you get?
Dan
Post Posted: Thu Mar 18, 2010 6:03 pm
Deceleration enrichment. The VSS is used by the ECU to tell when a low load condition is happening, and backs the fuel off.
Post Posted: Thu Mar 18, 2010 6:39 pm
And also ignition timing trimming due to the 'aerodynamic' load which is a function of vehicle speed.
Dan
Post Posted: Thu Mar 18, 2010 6:41 pm
Probs actually be called deceleration enleanment :wink:
Post Posted: Thu Mar 18, 2010 8:45 pm
Enrichment with a negative value pompoms
Vehicle: SJ80
Post Posted: Fri Mar 19, 2010 4:15 am
Righto, that makes sense...
Vehicle: SJ80
Post Posted: Fri Mar 19, 2010 4:33 am
JrZook wrote:
No problems!
Okay, so I've got a coily with 30's, a 1.3 leafy transfer case and as it's my daily driver, I do mostly highway driving. Corrected distance travelled is 449km. Fuel used was 54.66L. So a crappy 8.2km/L is the result. This is with standard unleaded (91RON no ethanol). With 95RON, I do a little better.
Post Posted: Thu Jul 14, 2011 12:49 pm
Maybe I've missed something, doesn't the Vitara speedo with the vss just bolt into the Sierra speedo cluster ? That's what I did in the past. Maybe I've missed something obvious.
Users browsing this forum: No registered users and 10 guests
