It is currently Sat Sep 26, 2026 8:38 am
Post Posted: Tue Feb 23, 2010 4:37 pm
The problem with the standard tin top ute cab is the depth at the back see pic
as you can see no room for a decent seat. Can't fit anything behind either
Rear of cab is spot welded in so... What do u reckon?.. Drill out the spots and reverse the back of cab so it faces out instead of in. Or drill out the spots and move the cab back and weld in a piece of steel?
You can view larger img.. here
http://s924.photobucket.com/albums/ad85 ... b%20resto/
98 GV
Post Posted: Tue Feb 23, 2010 5:25 pm
sounds like a damn good idea.
I never liked those cabs 'coz they're SO tiny.
Post Posted: Tue Feb 23, 2010 5:35 pm
I've thought about exactly the same thing for my ute. I haven't actually done it so I can't give any useful advice, but let us all know how it goes.
Good luck.
Post Posted: Tue Feb 23, 2010 7:06 pm
mine is a maruti and has a bit more room because of the fibreglass back, but even still its only just enough room for me to fit in gti seats.
Personally if going to that much effort i would try and add a bit more space for storage as well.
Post Posted: Tue Feb 23, 2010 7:59 pm
Yep know what you mean. I am thinking 100mm extension and down below tray height add some space for storage. Don't want to move the tray back too far. Is a short ute as it is.
98 GV
Post Posted: Tue Feb 23, 2010 8:37 pm
i want a cab like this
the build link http://www.pirate4x4.com/forum/showthread.php?t=313024
Post Posted: Tue Feb 23, 2010 10:36 pm
I've seen the drill out & rev, it look's wrong!!!
Yes it give's you more room, but every time you get into the car you look at it, it stopped me buying it bout 3 yr ago. 8O
Post Posted: Wed Feb 24, 2010 1:09 am
thats how to do it, cut up a tin top rear window and use the 2 halves
Post Posted: Wed Feb 24, 2010 1:49 am
mine also started life as a cab-chassis. cut the centre out leaving the gutter, then place as much of the rear of a hard top as you like. you would be surprised at how well it lines up.
Post Posted: Wed Feb 24, 2010 1:51 am
while I'm was keen on seeing how moving the back wall works I actually moved away from that idea. Now I'm planning to chop around 600mm from around the rear wheel well of a SWB soft top and joining it back together again.
I also have a fibreglass hardtop which I'll do the same thing to.
This is on a lwb so it won't look too rediculous (I hope)
Here are some amateur pics of the proposed mods:
Post Posted: Wed Feb 24, 2010 1:57 am
same thing was done to this....
Post Posted: Wed Feb 24, 2010 2:40 am
Thanks for the pic's and ideas I have some more research to do.
I like the look of the red one. Very tidy.
And yes I think the reverse would look odd! If I could of got hold of a fibreglass back I would of put that on and then built up the bottom section.
they are a bit hard to find and lots of $$
Thanks again
98 GV
Post Posted: Wed Feb 24, 2010 2:50 am
just wondered if I use the top and sides of a tintop will my original rear fit back in?? not so keen on the rear barn door look
98 GV
Post Posted: Wed Feb 24, 2010 3:13 am
then weld it in
Users browsing this forum: gbcrown, Google [Bot] and 37 guests
