It is currently Mon Sep 14, 2026 5:30 pm
Post new topic Reply to topic  [ 102 posts ]  Go to page 1, 2, 3, 4  Next
Vehicle: 85 SJ413
Post Posted: Sat Feb 27, 2010 7:20 pm
A mate of mine wanted rear disc brakes for his Vitara, so I have developed a kit.
It is a completely bolt-on conversion.
It uses standard Suzuki front brake rotors, and common brake calipers from a Mitsubishi Galant, which include a handbrake in the caliper and are sized correctly to work without an additional proportioning valve.
The kit connects the stock Suzuki handbrake cable to the caliper with no modifications to the cable required.
The kit contains:
Caliper mounting brackets
Disc mounting adaptors
Replacement caliper handbrake quadrants
Handbrake cable brackets
Brake hose brackets & clips
Handbrake cable mounting hardware
Longer wheel studs
All required mounting bolts
Brake hard lines pre-flared with nuts.
3-way T piece
Instructions
The only parts required are:
Mitsubishi calipers and brake hoses
Suzuki brake discs
Brake fluid.
Silicone sealer / gasket maker
Can be installed with simple hand tools in a few hours.
Price is $350AU + shipping
WWW.ZUKPARTS.COM - Quality Suzuki Off-road Parts
Post Posted: Sat Feb 27, 2010 8:39 pm
8O Wow 8O
Post Posted: Sat Feb 27, 2010 8:51 pm
steknig wrote:
8O Wow 8O
x2 my shopping list just keeps getting bigger. Good work Ben
Post Posted: Sat Feb 27, 2010 8:55 pm
Good stuff matey thats a little sweet kit ill be looking at geting one of these off ya soon :P
Post Posted: Sat Feb 27, 2010 10:44 pm
simply awesome Armsup
what year/model Mitsubishi Galant do the caliper come off?
Vehicle: 85 SJ413
Post Posted: Sun Feb 28, 2010 12:30 am
Thanks for the kind words guys..
Calipers come off late 80s early 90s Mitsi Galants
Ben
Post Posted: Sun Feb 28, 2010 12:38 am
ok silly question time... fronts or rears?
i'm guessing rears. 8O
Vehicle: 85 SJ413
Post Posted: Sun Feb 28, 2010 1:09 am
Oh yeah, my bad, forgot to mention that.
Kit uses the REAR mitsi caliper. Some budget spec 1.8 models have rear drums, but most have rear disc.
Post Posted: Sun Feb 28, 2010 1:30 am
Can you go without the disc adaptor and fit em up to later vitaras that have the wheel studs in the axle?
happy for you to send a kit over for me to try :wink:
Vehicle: 85 SJ413
Post Posted: Sun Feb 28, 2010 2:45 am
I haven't tried a kit on one of the later axles yet. I think I know where one of those axles is, so I will see if I can get hold of it and check.
Ben
Post Posted: Sun Feb 28, 2010 2:59 am
with the longer wheel studs is this gonna make our rear wheels stick out further? if so how much?
what type of suzuki front rotors do we use on the back? sierra? swb vit?
could be very interested.
Post Posted: Sun Feb 28, 2010 4:01 am
Ben
I would be interested in the kit for the later axle.
Post Posted: Sun Feb 28, 2010 4:21 am
Sweet! where do i sign up? Armsup
Go Hard, Trailer Home
Vehicle: 85 SJ413
Post Posted: Sun Feb 28, 2010 4:33 pm
Yep, your track width is increased slightly by the thickness of the centre piece of the brake disc - about 7mm per side.
Either will work, but Sierra ones line up slightly better in the caliper, as the Vit disc have 1mm less offset (f*ck knows why).
Ben
Vehicle: 85 SJ413
Post Posted: Sun Feb 28, 2010 4:41 pm
Ben
OK. I got hold of a later axle and did some checking. Unfortunately the newer axle has a different offset from the housing end to the wheel mating surface, so does not work with the current brackets. Also the seal housing can't be moved far enough away from the bearing to get the caliper bracket in place.
Could get round this by using a thin wheel spacer (about 6-8mm), longer studs, and a bit of grinding of the seal housing. This would require removing the wheel bearings to modify the seal housing though.
The better option is probably going to be me making another caliper mounting bracket with a bend in it to get the right offset, and slightly thinner to fit between the seal housing and the bearing. Then it would all bolt together easy peasy.
How many people have the later style axle and would be interested in this?
Ben
Vehicle: 85 SJ413
Post Posted: Sun Feb 28, 2010 4:42 pm
Send me a PM :)
Post Posted: Sun Feb 28, 2010 7:24 pm
Mine is a 96 EFI 1600 would mine be the later style axle?????
If so i would be interested in you making another kit :wink:
Post Posted: Sun Feb 28, 2010 7:37 pm
what yr does the later model axle come in?
i would be interested as well, i have the same as joe (96' EFI)
Vehicle: 85 SJ413
Post Posted: Sun Feb 28, 2010 9:59 pm
I think changeover is 96, so yours probably has the newer axle.
Easy way to check is to have a look in the centre of the wheel. If there are 4 nuts holding the drum on to the axle, then you have an early axle.
If there are no nuts in the centre of the wheel other than the wheel nuts, and the wheel studs are attached to the axle then you have the later style.
You will need to take the centre cap off to check this if you still have stock wheels.
Ben
Post Posted: Sun Feb 28, 2010 10:03 pm
put me down for a late model kit, when you get it sorted! 8)
Post Posted: Sun Feb 28, 2010 11:19 pm
mines 10/95 with later axles, if you have the later dash chances are you have the later diff
BenT, it would probably pay to check the later again 2lt and GV's as well to see if they would all share a common bracket before you tool up for it, GV's would probably be your biggest market
Post Posted: Sun Feb 28, 2010 11:25 pm
With the model Mitsu Galant. Do you have pictures of the model?
Australia did not get many Galants. And most of them are jap/nz imported. Nz got alot more variations.
Post Posted: Sun Feb 28, 2010 11:26 pm
valid point royce, i know the drums are a quite bit larger on my 2.0l vitara (SV420) compared to the 1.6l (SE416) i would assume the drums on the GV's are size similar to what i'm running.
Post Posted: Sun Feb 28, 2010 11:43 pm
hehe I know where there is one currently being driven by somebody known to destroy cars really fast, I already have my name on them :)
Vehicle: 85 SJ413
Post Posted: Sun Feb 28, 2010 11:57 pm
Yeah, good call. I will see if I can track down a GV diff to see how they compare.
BEn
Vehicle: 85 SJ413
Post Posted: Mon Mar 01, 2010 12:00 am
Yeah, we do have a lot over here. Some Jap imports, some assembled here, back when we had an automotive industry.
Here's a pic of the model. 89-93ish. E33 Galant.
Post Posted: Mon Mar 01, 2010 12:52 am
Have the later vit sv620 imagine it should be the same as atari. Keen for a kit when you get them sorted
Post Posted: Mon Mar 01, 2010 2:16 am
Yeah those basic Galants are rare over here. I think i have only seen the Import turbo 4wd ones.
We had the Australian Made Magna, so i don't think Mitsubishi Australia wanted 2 large cars on the same market here.
The Galants probably drove a hell of alot better though :lol:
Alot of brake calipers are probably very generic. So there may be another mitsu out there that is similar in aus with the same calipers. Maybe similar shape rounder magna's 91'+?
Anywho, The kit looks good Ben.T.
If i had a vit. I'd buy that kit!
(You dont do them for bundera/lux rear diffs do you?)
Post Posted: Tue Mar 02, 2010 7:07 pm
in other words, i'd need a set of these
http://cgi.ebay.com/ebaymotors/1990-199 ... ccessories
Post Posted: Tue Mar 02, 2010 10:24 pm
You need one of them & a left one, thay are different side to side.
Users browsing this forum: No registered users and 50 guests
