It is currently Mon Sep 28, 2026 11:36 pm
Post Posted: Tue Mar 02, 2010 3:24 am
ok so there is no noise at all coming from the gearbox when the engine is running and the clutch is disengaged (pedal pressed in)
but when i engage the clutch (pedal let out) a definate whining spinning sound starts and it goes with the revs of the engine, not the speed of the car
anyone have any ideas of what it may be?
thanks, fletcher
Post Posted: Tue Mar 02, 2010 3:28 am
Throughout bearing mate.
TWIN LOCK IT & JUST DRIVE!
Post Posted: Tue Mar 02, 2010 3:30 am
gearbox input shaft bearing
Vehicle: 07 vvt jimny
Post Posted: Tue Mar 02, 2010 4:10 am
same shit different smell
sorry CHOP :P
Jimny's Are taking Over
Vehicle: Serria
Post Posted: Tue Mar 02, 2010 12:20 pm
yeah x2 on throughout bearing
Sj80 cab on sj70 chassis 5inch lift 1.6 turbo inte
Post Posted: Tue Mar 02, 2010 2:56 pm
x2 what mrw82 said
It won't be throughout bearing, it will only make a noise when foot is on the pedal. Sierra's have a weak spot it is where the input shaft joins with the main top shaft . It is a needle bearing . If let go too long it will wear the shaft and the housing on the end of other shaft. Much more costly to fix then.
Best to get all the bearings done in one hit then it is fixed.
98 GV
Post Posted: Tue Mar 02, 2010 3:27 pm
thanks, fletcher
Definately input shaft bearing...
Throwout can only make noise when clutch pedal is depressed.
Users browsing this forum: No registered users and 186 guests
