It is currently Wed Oct 07, 2026 2:49 pm
Vehicle: SJ50 hardtop!
Post Posted: Sat Mar 13, 2010 12:01 am
Just bought a thermo from repco today and went to replace it. Pulled the old one out and it had a rubber ring around it and no gasket. The two seem to be a tad different; the origional was a perfect circle with the thermo centered and the repco one was a slight egg shape.
Is there supposed to be some sort of gasket (2 multi-purpose ones came with the thermo)?
I've just put the rubber ring around the new one and put her back together for the time being.
NT SJ50
Post Posted: Sat Mar 13, 2010 2:54 am
Also, whats the cable that sticks out the front under the thermo, right beside the dipstick? I snapped the clip thing and have temporarly fixed it for now.
Is it the temp guage sensor?
NT SJ50
Post Posted: Sat Mar 13, 2010 3:30 am
pics of cable thing?
Post Posted: Sat Mar 13, 2010 3:34 am
Ummmm, it's a bit dark at the moment. I'll take some in the morning.
It was a black clip that hooked onto the end of a bolt that screwed into the bottom half of the thermo casing on the engine block......if that makes any sense at all.
NT SJ50
Post Posted: Sat Mar 13, 2010 11:26 am
sounds right for the thermostat, tridon dont list it correctly
if its a single wire that pushed onto a terminal then yes its the temp gauge
Post Posted: Sat Mar 13, 2010 12:59 pm
I've had to go back to Repco to get that rubber gasket before.
They have two listed as suitable for the Vit so if you can take the old one you should be able to match them up. They are about $4 ea or so.
I assume if you use the rubber gasket you don't need the multi-purpose paper one but I'm not sure on that.
Hopefully someone here can teach us both.
Post Posted: Sat Mar 13, 2010 1:59 pm
I've used dayco thermostat's for year's, never have I seen the gasket's supplied fit, anything.
Buy a new gasket & use the supplied as ninja stars. :P :P
Post Posted: Sat Mar 13, 2010 4:34 pm
Yep, that's exactly what it is. Temporarily fixed it with a bit of wire for now :s
I just reused the rubber ring from the old thermo, and there doesn't seem to be any leakages from it yet. I presume the paper gasket is un-needed.
NT SJ50
Post Posted: Sat Mar 13, 2010 10:48 pm
neither had i till the other day..
but some dayco thermostats do come with them.
Post Posted: Sun Mar 14, 2010 11:29 pm
NT SJ50
Users browsing this forum: No registered users and 287 guests
