It is currently Fri Aug 07, 2026 6:22 pm
Post Posted: Sat Mar 13, 2010 2:23 pm
No rush but i'm contemplating selling the front locker and upgrading to a locked 26spline cromo setup. If anyone's got them in good nick then let me know.
Cheers,
Jimmy.
Post Posted: Sat Mar 13, 2010 2:29 pm
What locker is in it??
You should be able to get side gear's for it, thay just rear's..
Post Posted: Sat Mar 13, 2010 2:31 pm
You want air locker side gears or stock zook?
ARB sell a side gear kit...
Post Posted: Sat Mar 13, 2010 2:32 pm
Or I will swap you a std 26 spline for your locker.. :P :P :P :P :P :roll:
Post Posted: Sat Mar 13, 2010 2:36 pm
Its an ARB air locker - the front one (RD75)
I didn't know you could get side gear kits for them. I'll have a chat with my local ARB bloke and see what he can do.
Post Posted: Sat Mar 13, 2010 3:13 pm
i wanted to swap someone my front air for a rear air but had no luck i have the 26 spline side gear kit coming from the states for my air locker cheaper to buy over there than here just takes a little longer. $262us and $350 aus
cheers heath
1994 zook #12007-2009
1994 zook #2 2019 lets build another
Post Posted: Sat Mar 13, 2010 3:16 pm
hopw much you want for the locker? i have some side gears here.
Post Posted: Sat Mar 13, 2010 3:29 pm
Rythwrist, you don't happen to have part numbers I can quote? Or a link?
Sorry Brett, looks like I'm hanging onto it as long as I can get the side gear kit.
Post Posted: Sat Mar 13, 2010 3:35 pm
the part number for the set is 728g011
kit is 4 star gears and the 2 side gears.
best price i could get was about $315 but i guess it who you know that counts
Post Posted: Sat Mar 13, 2010 3:51 pm
rythwrist wrote:
... i have the 26 spline side gear kit coming from the states for my air locker cheaper to buy over there than here just takes a little longer. $262us and $350 aus
cheers heath
Is that the the ARB kit from the US you got?
I have the same problem and need the kit at some stage to refit my locker. I was quoted $380 here for the kit so haven't bothered yet.
Post Posted: Sat Mar 13, 2010 4:01 pm
yer it's weird,
us is still cheaper,
low range buy the the side gear kit from aus - aus post to us, then us post back to me in aus and still works out cheaper arb have so much mark up on the products.
i have rock assualt chromo coming from low range and the side gear kit for about $760 and to buy the chromo's from states and side gear from here was going to work out about $950
back in the day it was cheap you use to be able to just buy the side gears which were like $60 each
Post Posted: Thu Jun 02, 2011 11:47 am
Grave dig here sorry.
So if I get this 728g011 kit, I should be able to fit that to my RD75(altho I have the older style RD 73 which has the same part number 728g011 ) front Air locker and then run 26 chrome axles?
Post Posted: Thu Jun 02, 2011 9:13 pm
That's is corrected As far as I know
Users browsing this forum: No registered users and 30 guests
