It is currently Thu Sep 10, 2026 5:24 pm
Post Posted: Sun Jun 10, 2007 11:48 am
Can someone please tell me if I'm on right track. I want a easy kill switch fitted to a car. The way I think is works is:
Pos from coil to switch, and switch to earth. Am I correct? I don't want to play until I am sure. It's for Casper so no major electronics to worry about. Thanks
Post Posted: Sun Jun 10, 2007 1:55 pm
is it to stop it from being stolen or kill the engine in case of an accedent roll over etc..
LWB ca18det 37's etc
LWB g16a 31's etc
GU Twin c
Post Posted: Sun Jun 10, 2007 2:21 pm
Stop from (well slow down anyway) being stolen.
Post Posted: Sun Jun 10, 2007 2:55 pm
then any one who is going to steel it would know that a wire from battery to positive side of coil and a screw driver across starter will start a car if you have an electric fuel pump i'd cut power to that or in my monaro i have a high tensile chain bolted then welded to the floor with a high tensile padlock to go around steering wheel if they cant steer it they cant go far it all rolls up and goes in a zipped up bag attached to floor when not in use.
you could weld a shackle to your gear stick and paddlock it as well
food for thought
ps.. for the record i have never stolen a car
LWB g16a 31's etc
GU Twin c
Vehicle: MY2019 Jimny
Post Posted: Sun Jun 10, 2007 5:39 pm
Leave the stubby stick in Neutral - may buy you a few minutes...
Post Posted: Mon Jun 11, 2007 1:16 am
Ah!!!!!!!!!!!.....good one!!
Now Im just a bout clever enough to do this!!!....probably whilst bragging to my mates how clever i am not to get my car stolen...after a nite on the bundy, and leaving Sneaky at the train station............ upon return the next day Id probably;
1. try and drive it, give it a bit more than normal throttle action and 'pop' the cluch a few times thinking ive doen a clutch cable or similar...
1.5 swear a bit.
2. Change a transfer case on spec (in the carpark, in the rain) whilst winging about the quality of crawler gears available nowa days....
2.5 ring my missus and blame her for stuff unrelated to my predicament
3. After refiting the same tcase Id probaly drop the gear box, telling my offsider that I though i hear a strange noise when i negotiated the last woolies carpark ramp..
4.Accidently knock the lever into hi 2 an drive it home.
Thanks lumps, youre a great help! :wink:
Post Posted: Mon Jun 11, 2007 12:34 pm
Bruce,
Jaycar sell an immobiliser with keyless entry for $119 (Cat. LA8970) which is compliant with insurance requirements as it meets Australian standards. Will kill three circuits (eg. EFI, Fuel Pump and Ignition). Not fun to install, (all black wires) but it works well.
Only problem I have had is sometimes the battery in the remote gets dislodged and needs to be opened and refitted. I cleaned all the contacts with Metho, and it seems fine now. Must be sensitive to grease or something.
Rod W
92 Vitara JLX Wagon
Vehicle: LJ20 LJ50
Post Posted: Mon Jun 11, 2007 1:06 pm
Just put a switch in line Bruce.
Not to earth or you will blow the fuse
cut power wire to coil. Fit switch in line so that when switch is open no power to coil.
Or if you want to get tricky, use the switch to activate TWO relays. One that will cut power to coil and one that will cut power to starter soleniod.
Hide switch up under dash/in centre console/in seat/etc etc. Or put in middle of dash and mark it as spotlights, or make it turn on maplight as well.. That does actually confuse people.
Don't fit anything that has to be activated every time you start it. MAJOR pain if 4wdriving.
Camels have nice toes
Post Posted: Mon Jun 11, 2007 2:23 pm
is casper fuel injected or have an electric fuel pump
Post Posted: Mon Jun 11, 2007 6:33 pm
Job done and working.
Bit like jock said. I pulled pos wire from coil off. Fitted new wire from pos side of coil to switch. Then other side of switch to the wire that I pulled off pos side of coil. All works as i want it to. I know you can get all types of other stuff for kill switches etc. Switch is inside car somewhere. So when switch on you can't start the car. Switch off and it starts.
Thanks all for you're help. :-)
Post Posted: Mon Jun 11, 2007 11:12 pm
I'll set you up an improvment on your switch, so it starts but keeps stalling all the time, theirf thinks its a POS that wont go and leaves it :)
Post Posted: Tue Jun 12, 2007 12:32 am
OK mate thanks. So next time ya up you can do it. :-)
Post Posted: Tue Jun 12, 2007 12:36 am
Yeah I have one of those too - A dodgy carb!
Post Posted: Tue Jun 12, 2007 12:37 am
bwhahahaha :wink:
Post Posted: Tue Jun 12, 2007 9:37 pm
Fuel solinoid cut off switch?
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 113 guests
