It is currently Sat Nov 14, 2026 3:21 pm
Post Posted: Tue Jul 18, 2006 12:59 am
Anyone know how to make a endless air supply from a airconditioner compressor?
Post Posted: Tue Jul 18, 2006 1:11 am
it really depepnds on the type of compressor, but basics is you need to get the intake and outlet figures, put a filter on the inlet, a fitting or plumb to a tank on the outlet and preferebly a pressure switch to shut the compressor off
now it gets tricky, if you ru say a Sanden 508 compressor then you can tip a bit of oil in the fill hole nw and then and your laughing, if its a factory type one you may need an air inline oiler on the intake and a oil ait seperator on the outlet to keep it lubed
you can also get brackets for the 508 sanden from mobs that do aircon kits so you dont have to fab it up
Vehicle: 87 pathfinder
Post Posted: Sun Jul 30, 2006 8:19 pm
I made one of these systems easy as to make
and I can run rattle gun off it
If it ain't broke. I can fix that
Post Posted: Mon Jul 31, 2006 1:11 am
8) Got a pic and some advice :wink: ??
Post Posted: Mon Jul 31, 2006 1:40 am
Symon webpage
have a look here
Post Posted: Thu Mar 08, 2007 2:49 am
http://www.ackerdackerly.com/saccpv1.pdf
Users browsing this forum: Google [Bot] and 76 guests
