It is currently Mon Nov 02, 2026 4:03 pm
Post Posted: Mon Jun 18, 2007 11:21 pm
Hi Guys, i recently purchased a 84 Sierra with a 900cc 4cyl. A few days after buying it, i was taking the tranfer lever fromk 4L to 4H when i discover that the lever was stuck. There were no gears, no movement in lever, and it was not in neutral as the front diffs were still engaged.
So i got down and greasy and took the tranfer case out, took it to a mechanic, and found out that the selector had been bent and so on.
After hours of frustratingly tight work, the new box was back in, but as soon as the same action was taken, the transfer case was stuck between 4L and neutral (well thats what it looked like on the gear stick).
I was talking to my dad about it and he had a mate who used to build the transfer cases and he siad that the round selector that slides between the 4L and N and 4H gears was able to move too far, off the end of the spline or cogs and onto the shaft that had no cogs. So when i tried to force the lever back it would bend the selector arm.
Apparently a quick fix is to weld a ball on the end of the selector rod that controls these gears so as to stop it from being able to be pushed too far. no im sure precise measurments would need to be taken and i dont know what they are, but for the more knowledgable, it would make a lot more sence.
Anyway just thought id let you all know incase someone out there is wondering why transfer cases keep blowing on them:)
Post Posted: Tue Jun 19, 2007 12:02 am
Common issue but usually is the shifter sheet that is meant to sit under the transfer stick. make sure u have on in there. only $15 or so from the dealer.
Nic
If in Doubt Power out.
1.6 big block and twin loc
Post Posted: Tue Jun 19, 2007 12:04 am
really? can you give me more info or a link?
Post Posted: Tue Jun 19, 2007 12:28 am
pm bruce on the forum he makes and sells them pretty cheap and i beleive he may even post them out.
it is a [retty common problen that is easily fixed in 10 minutes pull the shifter out figure out where it should be in the gearslides and slip it back in, generally shouldnt have to take the whole transfer out but yours may have been different.
i got my gearbox stuck like that in 5th one arvo and had to drive home in 5th from the airport to redcliffe, but 10 minutes at home and she was good as new :D
Post Posted: Tue Jun 19, 2007 12:29 am
Yep I make tham and are the best price you will EVER get :-)
Post Posted: Tue Jun 19, 2007 12:31 am
Or extremelimits offroad on Ebay sell the complete kits for $40.00.
I make them for them LOL so I know they are good :-)
Post Posted: Tue Jun 19, 2007 12:49 am
Thanks pope and bruce. do the kits come with install instructions? if so, do you want me to buy them of u bruce or would you prefer i go to Ebay (only cause ud get more money the other way:)
Post Posted: Tue Jun 19, 2007 1:31 am
No it's about the same price but I can sell one part only. Makes no diff to me mate really just glad we can help you. The ebay guys are real good and I trust them 100%.
Instructions hum no but if ya having a prob just post up and we can talk you through it. It's not hard really. Just look first.
Post Posted: Tue Jun 19, 2007 2:04 am
so whats there user id on ebay i've been looking and i cant seem to find them
Post Posted: Tue Jun 19, 2007 5:22 am
http://cgi.ebay.com.au/Polyurethane-Bus ... dZViewItem
i have gotten one of these kits in the past.. very good work ;)
cheers
Post Posted: Tue Jun 19, 2007 10:25 pm
replied to your pm mate. here is a link albeit for a vitara but should help ya out. and others that may need the pics (as i did)
http://bbs.zuwharrie.com/content/topic,61157.0.html
Post Posted: Tue Jun 19, 2007 10:59 pm
smileysmoke wrote:
http://cgi.ebay.com.au/Polyurethane-Bush-Kit-Suzuki-Sierra_W0QQitemZ250132193000QQihZ015QQcategoryZ30862QQrdZ1QQcmdZViewItem
cheers
Yep thats the one I sell to ebay guys. If ya want to see other things they sell go to www.extremelimitsoffroad.com.au
These guys are real good to deal with. Just say Bruce sent me and they will look after you :-)
Post Posted: Wed Jun 20, 2007 12:19 am
http://www.outerlimits4x4.com/viewtopic ... 126#931126 and another link for ya.. these are of a sierra.. real simple.
Post Posted: Wed Jun 20, 2007 12:26 am
Good stuff there Smileysmoke. THat will help people out :-)
Post Posted: Wed Jun 20, 2007 3:45 am
no worries Bruce. glad to be of help mate ;)
i was stuck up in Lancelin when mine failed on me.. luckily i aligned the shifter guides and the shifter fell into place and got me into 2wd for the rest of the weekend :D
this is one of those fixes people should do when they first get a zook! i am going to replace the one on my mates zook soon also. before it goes on him also.
Users browsing this forum: Google Adsense [Bot] and 589 guests
