Joined: Sun Jun 17, 2007 11:30 pm Posts: 65 Location: Sydney
Posted: Mon Jun 25, 2007 11:19 pm
First thing as soon as i start rolling, my zook feels like the brakes are on and nearly stalls when i take off. i need to take off in 4L sometimes just to get moving. it eventually wears away though????? help me
Joined: Tue Aug 01, 2006 11:30 pm Posts: 3461 Location: licking some windows
Vehicle: LJ20 LJ50
Posted: Mon Jun 25, 2007 11:41 pm
handbrake cable may be seizing
Wheel cylinders may be siezed
Brakes may be over adjusted
Master cylinder may be seized
Transfer case bearings may be seized
Gearbox bearings may be seized
Wheel bearing may be over adjusted
Wheel bearings may be seized
Tyres could be flat
Diff bearings may be seized
Pinion bearings may be seized
two different size tyres on front and rear
Joined: Sun Jun 11, 2006 11:30 pm Posts: 7681 Location: Brisbane
Vehicle: 75 Cruiser
Posted: Tue Jun 26, 2007 1:13 am
sosi, have you got the front hubs unlocked ? if you have the front hubs locked you may be experiencing "wind up". Dont; drive around in 4wd on the streets.
apart from that go through TZARs check list. You could have some seized brake cylinders.
Vehicle: LJ20 LJ50
Posted: Tue Jun 26, 2007 8:36 pm
If it is a very early 1 litre you can't unlock the hubs. Also has drum brakes on the front and has 4 wheel cylinders at $40 each. Throw the whole lot away and get nt parts and slide them in. Bigger cv's disc brakes locking hubs for less than you can get the front brakes done.
Users browsing this forum: Google [Bot] and 110 guests
