It is currently Thu Nov 05, 2026 1:06 am
Post new topic Reply to topic  [ 48 posts ]  Go to page 1, 2  Next
Post Posted: Fri Jun 29, 2007 7:50 pm
Hi Guys,
Went down to the wreckers this morning and picked up a set of strut mounts for my Vitara. I took them home, pressed out the studs using a socket in a vice and drilled out the hole to 8mm and cleaned them up.
So I know I ned some 8x 1.25 mm HT bolts, and I assume some washers to pack up the underside, but what other tricks do I need to do to finish this job off?
Rod W
92 Vitara JLX Wagon
Post Posted: Fri Jun 29, 2007 8:15 pm
Never mind, I found it here, Sounds like I was on the right track...
http://www.zukiworld.com/forum/index.php?topic=13687.0
Rod W
92 Vitara JLX Wagon
Vehicle: 75 Cruiser
Post Posted: Fri Jun 29, 2007 10:17 pm
very resourcefull with the stud pressing thing rod :goodjob:
Post Posted: Fri Jun 29, 2007 10:41 pm
Thanks, I had hoped to reuse the studs, but the thread was well and truly destroyed and even after I ran a die over it, was still not good enough to use.
Rod W
92 Vitara JLX Wagon
Post Posted: Sun Jul 01, 2007 12:22 am
Once flipped I also packed a washer underneath and inverted the washer that was on top to give the rubber mount more chance of surviving when jumping sand dunes etc ... :lol:
All worked just fine for years now and I give it some when i can, best go now and work on maths for my so called buggered up rear suspension !
:wink:
Wendy's daily driver 97 Vit, which is getting hard
Post Posted: Sun Jul 01, 2007 12:46 pm
Sure your suspension is not the buggered one. Thought I'd do a bit of stirring.. :D
Rod W
92 Vitara JLX Wagon
Post Posted: Mon Jul 02, 2007 12:48 am
Buggered... its totally shot eh... hardly any movement due to constant binding and joint failures ... 8O
:wink: :wink:
Post Posted: Mon Jul 02, 2007 12:50 am
Hang on ... here's a pic .. you can see the binding and lack of travel quite clearly .. :oops:
Vehicle: 1994 Hard Top Sierra
Post Posted: Mon Jul 02, 2007 2:31 am
gee camp hill has changed so much
Jason
Navigator for Team Casper
Post Posted: Sat Jul 14, 2007 1:24 am
I replaced the front suspension with OME struts and springs today so now I know how it all goes together. I decided not to flip the mount just now because I was toying with making up a spacer so the mount stays right way up.
So when you flip the mount, I assume that you swap the washers over as well, so the top washer is swapped with the bottom one so everything sits on the mounts nicely. Can somebody confirm this for me. Thanks.
Rod W
92 Vitara JLX Wagon
Post Posted: Thu Aug 09, 2007 12:19 pm
Yes, you do install the flat washer on the lower end of the mount, and the funky non-round washer on the top, otherwise the strut could pop thru the rubber mount.
Post Posted: Thu Aug 09, 2007 11:18 pm
Mike,
Thanks for the feedback. I have more or less decided to put a strut spacer in instead of the flip to keep everything lined up nicely. I have my eye on some drop brackets so was planning 30mm strut spacers, 30 mm diff drop brackets and 30 mm spring spacers. so everything comes down together.
At the rear I was thinking of a 50 mm diff drop bracket and some spacers or extended springs and shocks or something.
But 'cos I'm not putting big tyres on, I might not really need to do anything much. We'll wait and see
Rod W
92 Vitara JLX Wagon
Vehicle: 1993 Suzuki Vitara 4dr Wgn
Post Posted: Sun Oct 21, 2007 12:40 am
Has anyone just left the plate as is (ie not remove the studs) and just flip the plate over and feed the plate from the top within the engine bay and bolt from underneath??
Would this create a "weak" point in that all the pressure is on the 3 nuts & the surface area under the nuts??
just curious......
Rob
'93 4Dr Vit, Red Gears,Bighorn 30" MTs, Sliders:B/
Post Posted: Sun Oct 21, 2007 10:08 pm
mine is done like that, IE through the top) but you still have to press the studs out as it wont fit in the hole int he guard with the studs on
Post Posted: Sun Oct 21, 2007 11:12 pm
When you think about this, all of the weight is on the spring, not the strut, so you should be safe provided the strut can't bottom out (ie. your bump stops on the springs are set up right to keep the weight on the spring). After all, you can compress the strut by hand.
Rod W
92 Vitara JLX Wagon
Post Posted: Mon Oct 22, 2007 12:41 am
I managed to get mine in from the top without removing all the studs (one stud was removed only). I just had to use a pinch bar to bend up (slightly) the part where the plate hits the inner guard when trying to insert the plate. You can't even notice where I had to bend up the inner.
When I find another plate I'll try with all studs still in place... :?:
cheers
Post Posted: Fri Aug 07, 2009 10:55 pm
ok this whole strut mount flip looks good, im in to things that are almost free.
how much does height and flex improve??
and can someone put a photo of it on here finished, so i can see what it "should" look like so i know i did it right? i'd rather not find out when the wheel falls off :-)
AND more of a step by step would b handy. im not really a mechanic.. :-)
Post Posted: Mon Dec 06, 2010 4:16 pm
Fllat washer on lower end of mount?? where? is that washer alreadon the shock?
Post Posted: Tue Dec 07, 2010 8:34 am
Im thinking about doing the mount flip my struts are fully topped out at the moment will this help? which way is best to do it?
Post Posted: Fri Mar 04, 2011 8:03 am
Found this very helpful.
I like his "spacer" idea
http://www.suzuki-forums.com/suzuki-sid ... ice-2.html
Post Posted: Fri Mar 04, 2011 8:08 am
Having Old Man Emu struts, mine already has 30 - 40 mm extra travel,
but I have lost this with the 25mm (thus 50mm lift) coil spacers.
(So presently have stock Vit travel roughly)
Thinking I don't want to stress cv's too much, or spend any more money,
I may do the strut mount flip,
as is less of a droop than the strut mount spacers available,
and I shouldn't need to bother with diff drop brackets,
as that feels counter productive?
Just thinking out loud, while waiting for me HD Idler arm to appear.
Post Posted: Fri Mar 04, 2011 10:29 am
I ended up doing the mount flip was really easy and done the trick no more topping out on a stone lol
Post Posted: Fri Mar 04, 2011 10:34 am
My spending spree has to end, nearly out of Sierra parts to sell :(
Can't keep getting pension advances. :oops:
So basically back to cheap stuff, and/or build stuff again.
But thats ok, its part of the fun :)
Post Posted: Fri Mar 04, 2011 10:37 am
PS
And fitting of some of the strut spacers for sale looks quite fiddly, an upturned mount be a bit easier.
Does the rubber bush go in upside down, too, easily?
Post Posted: Fri Mar 04, 2011 7:38 pm
does the spacer on the rear help any
Post Posted: Fri Mar 04, 2011 11:17 pm
If you mean A-arm spacer, or coil spacer, yes to both.
Post Posted: Tue Mar 08, 2011 9:05 am
It was easier than I expected, too.
Though with the already longer travel of OME struts,
I am hoping it aint too much for cv's
Post Posted: Tue Mar 08, 2011 9:11 am
Thats how I did it, right or wrong.
Wasn't able to flip the actual rubber mount over, as it wouldn't come out.
I had to drill out the funky shaped washer to fit the strut.
Post Posted: Tue Mar 08, 2011 11:27 pm
My spring is still under lots of tension at full droop.
I added bump stop spacers of 30mm, coil spacers of 25mm,
and the strut flip added about 25mm, so it is close to stock OME travel.
So all should be fine with strut flip on OME.
Unless the CV's go on strike for better conditions.
I can see how much they work in these photos.
Post Posted: Tue Mar 08, 2011 11:49 pm
Thats a CRAZY CV angle! 8O
Users browsing this forum: No registered users and 274 guests
