It is currently Wed Sep 23, 2026 6:33 am
Post Posted: Mon Apr 19, 2010 8:35 pm
ok i installed the falcon alterator in my zook
noticed my lights where real doll the other night but brightened up as i ut my foot down so i thought it would be something to to do with an earth so i unplugged every thing electric that i put on it as it was running good till then
whilst doing so i found out that my alterator is geting 14.5 volts in to it aswell as putting that much out im kinda confused as how ive stuffed up
cheers buzzy
-indebt 4x4 club-
nav 32s n winch cust rear
Post Posted: Mon Apr 19, 2010 8:59 pm
Try changing your wires. One is a sense the other the battery feed I think. Either way try the swap it might work???
Post Posted: Mon Apr 19, 2010 9:01 pm
you should be getting 14.5 volts to charge up the battery. but how much equipment were you running? you have to much load on the alterator.
Post Posted: Mon Apr 19, 2010 9:07 pm
110 Amp, I doubt it
Vehicle: MY2019 Jimny
Post Posted: Mon Apr 19, 2010 9:08 pm
On a 110A alt? not likely in a zook.
Post Posted: Mon Apr 19, 2010 9:12 pm
yer true that. my bad
Vehicle: LJ20 LJ50
Post Posted: Mon Apr 19, 2010 9:16 pm
Disconnect the coil HT lead and put your hand on the end of the coil and then crank the engine over. If you get a little tingle then its not the alternator.
If there is no tingle try putting battery acid in your eye
Camels have nice toes
Post Posted: Mon Apr 19, 2010 9:22 pm
sorry tzar but im not really tempted try something u sujest to me as u probly would rather me dead
no offence but u just dont seem to like me all that much
-indebt 4x4 club-
Vehicle: LJ20 LJ50
Post Posted: Mon Apr 19, 2010 9:24 pm
Meeee??????????????
Your better than you used to be, now we pick on you like a little brother rather than the braindead retarded wank stain that you were
Post Posted: Mon Apr 19, 2010 9:25 pm
:roll:
Post Posted: Mon Apr 19, 2010 9:31 pm
Meeee??????????????
ok point taken u could of just said im not a likedoingfatchicks anymore lol
and u would of hi the nail fair on the head :D
-indebt 4x4 club-
Post Posted: Mon Apr 19, 2010 9:32 pm
Hmm a bit like dave telling someone to weld a full fuel tank...
Be sensible guys, someone may take something posted here seriously...
I want my old sig back :(
Post Posted: Mon Apr 19, 2010 9:37 pm
sorry but i find that kinda funny
if someone is dumb enough to even take that seriously they shouldnt be near a car
i lost my great uncle/pops twin brother to a explosion
he was an engineer/welder was given the task of welding up a tanker it had been drained and cleaned out properly (aparently) how ever once he touched the rod to the tank boom up it went
moral of the story is its not so much about the pertol its self its the fumes that r the real flamable item
-indebt 4x4 club-
Post Posted: Tue Apr 20, 2010 1:03 am
From a previous post , is your fan belt tight , Cheers Paul.
Vehicle: SJ80
Post Posted: Tue Apr 20, 2010 1:47 am
X2 Drive belt to the alternator sounds like it could be a little loose. Doesn't take much, the falcon alts tend to need pretty good tension to keep em turning fast enough.
Post Posted: Tue Apr 20, 2010 2:14 am
its putting enough out but its also taking power in thats wat im worried about
-indebt 4x4 club-
Post Posted: Tue Apr 20, 2010 2:29 am
how do you know its drawing power/ do you have a clamp amp meter to check?
whats your battery voltage engine off, at idle at 2000rpm and at 2000rpm with all the electrical stuff turned on?
the coil thing is fun, I have got 2 people to do that, one even did it twice :)
Post Posted: Tue Apr 20, 2010 2:32 am
ok better way of wording it would be that there is 14.5 volts going in to the alterator as well as coming out
and yer wasnt really silly enough to take tzars advice on that one lol
-indebt 4x4 club-
Post Posted: Tue Apr 20, 2010 2:45 am
what do you mean there is 14.5 volts goin into it. On what wire?
Vehicle: 79 Lj80 stockman 94 swb Sierra
Post Posted: Tue Apr 20, 2010 2:49 am
x2
Are you taking about the sence wire or the charge wire??? :?
They should both read 14.5 volts
We are amphibious
Post Posted: Tue Apr 20, 2010 2:50 am
ill get pics tomorrow to explain better
the origanal wires that have the suzuki plug i cut that off and worked out wat was wat and used the female clamp clips that is wats putting the 14 volts to the alterator thats y im a bit confused
-indebt 4x4 club-
Post Posted: Tue Apr 20, 2010 2:56 am
Sence wire should have 14.5v (or what ever current charge at battery is)
This is to control the internal regulator
We are amphibious
Post Posted: Tue Apr 20, 2010 3:00 am
so its fine ????
-indebt 4x4 club-
Post Posted: Tue Apr 20, 2010 3:13 am
yerp.
As long as it reads exactly the same as the battery your all good.
We are amphibious
Post Posted: Tue Apr 20, 2010 3:22 am
cheers shaggs will get the muti meter on the battery tomorrow and give it a lookie loo
-indebt 4x4 club-
Post Posted: Thu Apr 29, 2010 3:36 am
ok it turns out my alternator is cactus had a auto sparcy have a look at it and the alternator is spiking and dripping causin my lights to die so might have to put the original alternator back in
-indebt 4x4 club-
Users browsing this forum: No registered users and 200 guests
