It is currently Sat Sep 12, 2026 2:49 am
Post Posted: Fri Jul 06, 2007 7:28 pm
am i crazy or are diff breathers just tubes that change the point where the diffs draw air from.
If thats the case couldn't I avoid the $70+ some shops are charging and DIY with some rubber hose?
(Im asking because I just had a $600 bill for a new bearing after it appears water got into the diffs :evil: )
[img]http://www.auszookers.com/modules/coppermine/
Vehicle: 75 Cruiser
Post Posted: Fri Jul 06, 2007 7:34 pm
yeah, easy as, just make sure you use some oil resistant kind of hose, not garden hose. keep it away from the exhaust pipe, i melted mine once :oops: ... and run it up somewhere, can be in to the airbox or even under the dash etc etc, you could put some filters on the end if ya like. I think jimny did this in his build up thread recently. ... and check your diff oil occassionally too just to make sure :)
PS. $600 for a new bearing? get outa here ! 8O
Post Posted: Fri Jul 06, 2007 9:48 pm
I have used garden hose why is it not good?
I have run mine up into the engine bay because apparently if you run them into the cabin it smells a bit?
Mine work great but still check the oil after every trip! 8)
$600 is a bit steep!
back in a built sierra!
Vehicle: 75 Cruiser
Post Posted: Fri Jul 06, 2007 10:34 pm
i can't rmember the technical term, but garden hose isn't made to resist oil. So it will deteriate faster. It may go hard and crack etc. Just keep an eye on it i guess.
Yeah i remember old Jeff had his rear breather piped in to the back of the vitara and the rear diff blew up or something and filled the car with a horrible oil smell :lol:
Post Posted: Fri Jul 06, 2007 11:35 pm
and the problem with nice smelling EP gear oil is ??? :lol:
I just used oil/fuel hose with cheap fuel filters on each end to keep things clean, Front Diff and gearbox (dont forget the box) up into high spot in Engine bay and rear diff up into cavity behind tail light (up high). Easy and cheap...
Wendy's daily driver 97 Vit, which is getting hard
Post Posted: Sat Jul 07, 2007 12:12 am
Most types of air hose are oil resistant. 12mm ID fit over the top of the barb coming out of the diff. Most purpose built kits use 6mm. Don't run the pipes into your cab and don't connect your breather to your radiator overflow like someone I know recently did.
Post Posted: Sat Jul 07, 2007 12:48 am
hahah thats gold. Did he blow his diff?
Suzuki's - It's not the size,
It's how you use th
Post Posted: Sat Jul 07, 2007 7:19 pm
Post Posted: Sun Jul 08, 2007 8:55 pm
mmmm i had worst case scenario:
after the trip I had to go right off to work (dominos driver, 150km)
then the bearing went and the axle seal blew as a result.
when the axle seal went the diff oil sprayed all over the brake drums, so the pads perished and needed to be replaced
and the perished pads wrecked/warped the wheel cylinder when they got jammed open and they had be replaced.
all up i ended up with a bill that resembled a rear diff parts catalog
(there was some more that happened but I dont care to recall...)
the moral of the story is check diff oil before driving 200+ k's and wondering "where is that whining noise coming from?..." although i didnt really think about it until i came home the next morning after a night out to find a puddle of oil in the garage... :oops: (so does anyone know how to get the stuff off the concrete???)
Ill whip up some breather this week end, are filters realy needed id I put them somewhere away from dirt/dust?
Post Posted: Mon Jul 09, 2007 9:37 pm
i used air hose like stuff used for air compressors and so on. lasted so far and is pretty hardy. garden hose will do fine but yeh may go hard if exposed to too much heat.
rear breather can be fed up next to the fuel filler pipe. just cut some rubber out and squeeze it up and in there.. then silicone to be safe.
i am thinking of attaching mine into the airbox instead of the fuel filters but the filters are cheap and easy.
atari - very neat setup i like the way everything looks in its place.
Post Posted: Tue Jul 10, 2007 6:46 pm
Your setup is nice as Atari :D. What are the silver things? What model + year is your car? And is that a strut brace I can see?
Thanks
'94 Vitara: 2" lift, BFG 235/75R15 MT's.
Datsun 2
Post Posted: Tue Jul 10, 2007 10:50 pm
Thanks
cheerz mitchy,
my zook is a 97 j20a vitara with the standard strut brace! the silver things are alloy valve caps with the rubber "O" ring removed, i trimmed the "barbs" off 2 sides on the top of the filter so valve cap still screws on & you can blow thru it easy & they only just screw on as a bit of bling & protection.
atari4x4
Post Posted: Tue Jul 10, 2007 11:02 pm
heh, :blingbling:
mine come with extended diff breathers need to make the rear one longer.
how long did the breathers take to do?
Vitara gone, tis no more. replaced by a 98 XH Falc
Post Posted: Tue Jul 10, 2007 11:22 pm
they took no time what so ever compared to the other stuff thats been done, LOL. all up a couple of hours taking it easy....
the vitara has breathers front, rear & one for the gearbox & transfer case which reminds me i still need to extend the gearbox breather!
Post Posted: Tue Jul 10, 2007 11:42 pm
were are the gearbox & transfer case breathers located?
Post Posted: Wed Jul 11, 2007 12:17 am
it should be at the back of the block/bell housing. my 2.0 has the two breathers joined together by the front of the gearbox then a common breather that runs up to the the back of the block.
Post Posted: Wed Jul 11, 2007 12:39 am
Where do you run the lines from the breathers to up under the hood?
Post Posted: Wed Jul 11, 2007 1:29 am
just follow the chassis rail
Post Posted: Wed Jul 11, 2007 5:38 pm
gotta try and get me one of those strut braces
Datsun 2
Post Posted: Thu Jul 12, 2007 12:03 am
hey mitchy,
my 2.0 vitara is a fair bit different to the 1.6 vitara I would guess that the strut brace would be 60m wider from strut top to strut top compared to your 1.6
Post Posted: Thu Jul 12, 2007 4:26 am
i went to have a go at it today, but couldn't get those stupid stock caps off :x
any hints???
Post Posted: Thu Jul 12, 2007 6:43 pm
Ahhh right thanks, yeah the guy at fulcrum said something about gvs having strut braces, but probably wouldn't fit either.
Datsun 2
Post Posted: Fri Jul 13, 2007 1:26 am
Hey Steve, I actually used the Pirahna kit and have had a couple of probs. The caps are only plastic and keep breaking in the original position. They've since been repositioned and believe it or not I just went out there to take a photo of the new position behind the headlight for you guys and one of them is broken again. Before I thought pressure from the bonnet might have been breaking them, now I know its just cheap crap. I'll be going back to see Lance with this.
Zooks Rule
2005 Jimny Z Series with VVT
[img]h
Post Posted: Fri Jul 13, 2007 8:53 pm
:oops: oops :oops: I should have listened to you steve. I put min in, went for a drive, and sure enough they had moved just enough to rest on the exhaust and melt the pipe in two. sigh, ill start again :roll:
Vehicle: 75 Cruiser
Post Posted: Fri Jul 13, 2007 10:01 pm
hah, yeah, atleast you noticed it :)
Users browsing this forum: No registered users and 99 guests
