It is currently Sun Nov 15, 2026 12:53 am
Post new topic Reply to topic  [ 41 posts ]  Go to page Previous  1, 2
Post Posted: Thu Apr 22, 2010 9:38 pm
if you went coil you could prob do it with out the chassis ext.
get a set of rover arms and away you go
Post Posted: Fri Apr 23, 2010 1:25 am
your going to trailer it soon... just wait and do it properly. 4 link front and air shocks
Post Posted: Fri Apr 23, 2010 3:40 am
that looks sweet
 Profile YIM
Vehicle: 4wd
Post Posted: Fri Apr 23, 2010 3:48 am
Im so over leafs...
It's just that time of year
Watch out or you'll get sued.
Post Posted: Fri Apr 23, 2010 4:15 am
pubic tig welded his. its awesome i love it.
but what i would do. is see if you can cut the chassie and section to be welded in on an angle. that way there is more weld in there and then maybe fish plate it with some 3mm each side. i seen a pic on outers by gwagonsteve he did the same thing but didnt fish plate.
ive got the gear to do it but sadly ive got no gas and havnt got the argon and argoshield on the account yet. was given the bottles ages ago
i could MMA it but i wouldnt be too confidendent doing it to somone eles car. havnt MMA done positional MMA in a while
also use MM. no one used CM a. i read 'adding 25mm to chassie' i was like wtf why would you bother. :lol:
navara on 33s. hopfully rear air locker soon
Post Posted: Fri Apr 23, 2010 4:16 am
please explain??? pictures??? I have been toying with the idea of coiling the rear. After seeing the tazy big job zookanator.
Post Posted: Fri Apr 23, 2010 4:28 am
Coils you won't need the massive overhang for the shackle/springmount.
Post Posted: Fri Apr 23, 2010 5:01 am
Yahh I understand that. I was just asking about the rover arm thing
Post Posted: Fri Apr 23, 2010 5:08 am
Rovers get alot of flex stock. As the bushes are different to most.
I will be using pootrol bushes in all arms, doin prob 3 / 4link fr and r
Post Posted: Fri Apr 23, 2010 1:47 pm
just back to the original post - mines pretty much that setup - although about 120mm chassis extension (or was it 150?) i forget...
Here's build pics:
More: http://www.suzistore.com.au/shopcontent ... customwork - click "SPOA CONVERSION"
Build thread on outers with more pics: http://www.outerlimits4x4.com/phpBB2/ft ... -asc-0.php
You're going to need a trac bar as well!
Post Posted: Fri Apr 23, 2010 11:38 pm
have a look under a rover, very simple. the chassis is nearly the same width as a sierra. its just a rod to locate the diff and the 2 arms.
Users browsing this forum: No registered users and 65 guests
