It is currently Fri Jul 24, 2026 2:40 pm
Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2
Post Posted: Tue May 04, 2010 11:52 am
next lesson I might talk about real high strength carbon steel pipe used in gas wells that would make ace tube bars
Or would they be pipe bars?? 8O ;)
I want my old sig back :(
Post Posted: Tue May 04, 2010 12:25 pm
pyrohamish wrote:
aaaahhhhhhhhhhrrrrrgggggggggggg
All I want is to build an exo and some barwork, eg sliders, front and rear bars
will one of these do the job?
assuming that i use say 32nb?? i think thats one everyone is using for exo's
yes it will do the job just not perfectly. just like you can take a vitara offroad but a sierra would be better :D
Post Posted: Tue May 04, 2010 12:32 pm
while im not gonna say these benders are great.They do work tho
If you have a look at my members rig page(appsie)
and (aerenandmels) they are both exos and other barwork done with one of these style benders.They are not perfect but have minimal kinks and both cars have been on their sides pretty hard a few times.Mainly used 32nb,but some 25 and 20 also
Vehicle: 105 landcruiser
Post Posted: Tue May 04, 2010 8:18 pm
I get die sets for my speedworx bender for under $500 a set. Still dear, but it works every time.
been thinking about getting one of these benders for a while and they're local for me :D
Vehicle: '85 Sierra LWB Ute, Lkd 33's
Post Posted: Tue May 04, 2010 9:03 pm
You've got a good looking cage there appsie, same sorta style I want to make
Im not so worried about looks, more about not bending everything in a roll, esbecially since my a pillars the metal is torn at the top due to a previous roll
Post Posted: Wed May 05, 2010 6:35 am
i have been thinking of getting a benader for a while now just got a quote for one of these standard duty package for $679 with freight. not bad i thought. might be an option.
Post Posted: Wed May 05, 2010 10:38 am
you can also help stops the pipe or tube kinking what ever you are using cap it and fill it will sand.
Vehicle: zook
Post Posted: Wed May 05, 2010 11:02 am
This is the bender to get. I have been using this type for bending 2" x3mm tube for rocksliders for various vehicles.
It will depress the inside of the radius and stretch the outside slightly flatter but wont kink the tube. As suggested above though, packing the tube with sand and welding caps on the end will prevent this somewhat. Similar technique to mandrel bending
Post Posted: Wed May 05, 2010 11:22 am
have a good read..............
http://www.pirate4x4.com/forum/showthread.php?t=376183
Post Posted: Tue Nov 30, 2010 2:50 am
Just to add now...
These new benders from Kincrome, has anyone tried one before?
I know it says pipe bender but it seems like a decent price and hoping it would do an alright job for sliders and rear bar work.
http://www.kincrome.com.au/web/catalogu ... ber=K12085
Post Posted: Tue Nov 30, 2010 2:54 am
crewsy wrote:
Just to add now...
Same as all the others. Just a differnt colour :?
Post Posted: Tue Nov 30, 2010 5:29 am
If you want a good pipe bender this is what I use.
http://www.jd2.com/shop/custom.aspx?recid=7
I wasn't able to find anything better in aust.
I use this for making roll cages out of cromemolly. Expensive to set up but you get a perfect bend every time.
But if you just want to make a dirty old low impact cage I guess you could afford to have half cocked bends.
Post Posted: Tue Nov 30, 2010 5:47 am
with these cheap pipe benders, would heating the tube and bending it slowly. would this still kink the tube, or will heat weaken the tube
Post Posted: Tue Nov 30, 2010 5:50 am
They are pipe benders, not tube benders.
You can try heat, filling them with sand and all the other crap. They are cheap because they give a cheap result. They will almost ALWAYS flatten the top of the bend, and most of them will leave a dint at either end of the bend where the pins were resting against the pipe.
It will get the job done, but don't expect professional quality.
Users browsing this forum: Google [Bot] and 337 guests
