It is currently Mon Sep 21, 2026 4:22 am
Post Posted: Fri Apr 30, 2010 11:18 pm
hi, does anybody know if a 1.6 transfer case will mate up to a v6 gearbox?
thanks, skinny.
Post Posted: Sun May 09, 2010 6:30 am
Need more info......
Post Posted: Sun May 09, 2010 6:33 am
thanks, skinny.
No, look the same, but no.
Post Posted: Sun May 09, 2010 9:38 am
depends on the size of the v6.
Post Posted: Sun May 09, 2010 9:46 am
So the SV's fit?? :?
I know the SQ's are different.
Post Posted: Sun May 09, 2010 9:52 am
thanks for the info, i'm a bit new at this, my friend has just bought a 2 litre v6 auto and the 4wd lever keeps jumping back out of gear while attempting to hold it in, and in the dirt with the brakes lightly on does'nt seem to transmit power to the front wheels? oh,it's got those horrible auto hubs too.
i'm used to simple sierra's. thanks
Post Posted: Sun May 09, 2010 9:58 am
does it have a body lift?
might be worth pulling the lever out and seeing if the selector is bent mine did the same thing after a log pushed my transfer case right up. But have read of it happening when people leant on them
Post Posted: Sun May 09, 2010 10:07 am
she's stock standered height and is it possible to get to the selector when the lever is pulled out?
Post Posted: Sun May 09, 2010 10:10 am
more info just came in, it seems to jump mainly in low range.
Post Posted: Sun May 09, 2010 10:16 am
from memory a wise old suzuki mechanic once told me there was an issue with a very select few t/cases that had thier synchro rings installed ass about which would cause your issue.
Post Posted: Sun May 09, 2010 10:22 am
oh lovely, i was hopeing for something simple that did'nt involve dismantling it. but thanks
Post Posted: Sun May 09, 2010 12:52 pm
Synchro rings? In a transfer case? Why?
Post Posted: Sun May 09, 2010 8:18 pm
Ease of operation, ever noticed you can move out of & into low when the car's moving??
Post Posted: Sun May 09, 2010 9:21 pm
you know what i mean (engaging collar). they are different thickness front to back, if installed the wrong way won't engoge properly.
Post Posted: Mon May 10, 2010 11:55 am
thanks very much guys, i'll let her know.
Post Posted: Mon May 10, 2010 12:22 pm
No "synchro" rings in transfer cases , only selector hubs.
i would be betting on worn engagement teeth on 4 low gear and selector hub outer ring
Users browsing this forum: No registered users and 209 guests
