It is currently Tue Oct 20, 2026 5:26 am
Post new topic Reply to topic  [ 35 posts ]  Go to page 1, 2  Next
Post Posted: Sun May 09, 2010 1:16 am
So my 30/9.5R15 Maxxis Mudders are getting pretty light on for tread, so i'm wondering (after seeing these www.cl-link.com/photo/66_5.jpg ), what would be the pros or more importantly any cons for going a tyre in a 215/85R16? These are equivelent to a 30-31/8.5R16. I know they're pretty skinny, so obvious disadvantage on sand, but my main driving is mud and rutted fire trails. I want my zook to be a bit different, so a departure from the usual 'fattest tyre possible' trend is a definite option. I've found a cooper Light Truck tyre in a At pattern in this size and I know that their tyres are great quality.
92 Sierra Hardtop, 2" OME Lift, 30" Maxxis Mudders
Post Posted: Sun May 09, 2010 1:49 am
its a very good idea... think of a tank when you think of tyres...
40+tons of steel on 2 skinny tracks... its the length of the tread that provides you traction, not the width. When you air down a tyre your aim is to increase its length on the ground giving more tread to grip it.
Now consider - what brands are available in that size and are you happy with those tread patterns?
I engineered mine for 31x10.5r15 as its a common size and very available, it was also the biggest i could go with WA's stupid laws (which are now worse). My next set will most likely be 32x9.5 swampers.
Post Posted: Sun May 09, 2010 2:09 am
A mate runs a good year wrangler in a skinnier size on his tourer an absolutely swears by them..
He is doing all kinds of terrain and says they are perfect on everything.
215s are farely thin though.. I would look for something a little wider .. Maybe a 225 or wider again as the tread pattern tends to get tight with smaller sizes... So less self cleaning
Post Posted: Sun May 09, 2010 2:57 am
a skinny tyre is a good idea tho as it will just cut through the mud and not just hit and sink bering in tassie mud is our main tracks so it would more then likley work better for u
-indebt 4x4 club-
nav 32s n winch cust rear
Post Posted: Sun May 09, 2010 3:35 am
I run 32x 9 swampers and they work great and i wanted to do the same go away from the widest tyre possible look.
TWIN LOCK IT & JUST DRIVE!
Post Posted: Sun May 09, 2010 7:36 am
I'm a big fan of skinny tyres for the reasons outlined above ( but did you know skinny tyres are better on sand that fat tyres?) however, I don't think I'd go with 215's. They're an uncommon size, so you have a limited range of replacements, and also check their load rating- lots of narrow 16's have sky high load ratings that don't conform well on a Sierra.
Personally if you are going to narrow 16's I'd step up another inch to 7.50 16's or 235 85 16- more tyre availability and a bit longer footprint.
Post Posted: Sun May 09, 2010 10:34 am
what sort of swamper are you running?
Vehicle: Suzuki
Post Posted: Sun May 09, 2010 12:31 pm
Like this Alien?
Post Posted: Sun May 09, 2010 1:16 pm
nar more like this: http://www.youtube.com/watch?v=P5aWAW2h ... re=related
As steve informed me the other day - the TSL Bias is available in 32x9.5!
http://www.intercotire.com/tires.php?id=10&g=1
Vehicle: 91 Sierra
Post Posted: Mon May 10, 2010 2:20 am
Post Posted: Mon May 10, 2010 2:45 am
There is the 32x9.5x15
and the 32x9x16 (This is what Junior_91 has)
So a little skinnier if your happy to go to 16" rims :)
I'm still not 100% sure on TSL's myself, the lack of sidebiters bothers me.... But I have plenty of time to check out some more cars in action with different tyres on them :)
Clearance Hole Technology :P
Vehicle: Suzuki
Post Posted: Mon May 10, 2010 3:09 am
Post Posted: Mon May 10, 2010 6:15 am
I noticed that also - but then look at the simex - they hardly have anything on the sides too. I'd love the LTBs but they dont come in the smaller sizes - they have both siping and side biters!!!
Post Posted: Mon May 10, 2010 8:04 am
The lack of "sidebiters" isn't really an issue unless you over-rim them. Stretched out, the sidewalls protrude and I agree it's a problem, but if they're on the right size rim the largest side lug pretty much protrudes past the sidewall so it's doing the work of the sidebiter.
The key issue here is the usefulness of the sidebiters is the width of the tyre. We have a spread of cars running 35's in the club - both Q78 swampers (10.5 wide) and Krawlers in 35 13.5. The '78's match the Krawlers for forward traction, but the massive width of the 13.5's jams into the ruts and makes the sidewall traction work. This much sidewall traction would be pointless on a 9" wide tyre as it's never going to fill the rut out enough to make it work.
Post Posted: Mon May 10, 2010 9:59 am
but steeeeeeve sidebiters look coooooool!
Post Posted: Mon May 10, 2010 2:41 pm
Sort of sorry to the O.P. for bringing sidebiters into the arguement, if its to off topic, please move it.
I realise that sidebiters are only of use in some situations, and in fact I can not make such effective use of them on my LJ, because I cannot drive the vehicle as slow and controlled. However on my Sierra, I can basically drive certain things on the sidewall of the tyre; ie say 2 tyres on their main tread area, and place one tyre so that it only touches ground on its sidewall; then I can still achieve forward motion unlocked. Very situation secific of course, usefull about 3.26% of the time :lol: but still I like to be able to do it.
Back to skinny tyres :P , I am really keen on my next set of tyres for my LJ being 7.00-16 Maxxis Creepy Crawlers :twisted:
Yes they make them: http://www.maxxis.com/AutomobileLight-T ... awler.aspx
Post Posted: Tue May 11, 2010 6:10 am
I like tall skinny tyres. 225/85R15 that would suit me although would be a little narrow for my pretty rims :-)
Post Posted: Tue May 11, 2010 6:40 am
Sidebiters are fine and this is a tyre topic, so all considerations welcome. I actually had a set of 33/12.5R15 Mickey T Baja Claws on my last car, a 94 Pathfinder with 3" Automotive Customizers long arm kit and 2" body lift. They have great sidebiters and were used LOTS! The biters would be something I'd look at considering I'm in Tassie and a track here can be dry and rutted one week, then muddy as hell the next. I've been trawling around some tyre distributor sites on line and it seems skinnies are pretty rare to find. Probably will steer away from TSL's and the super aggressives as I use the zook as a 110km round trip daily driver for work, lloking more at a quality AT.
Post Posted: Tue May 11, 2010 6:41 am
I'll post it again cos i think theyre a great looking tyre - the BFG KM2.
Post Posted: Tue May 11, 2010 9:07 pm
HighwayStar, those Creepy Crawlers look like hold and could definitely be on the cards if i ever look for a separate set of play tires, mounted on some nice tough steelies, would certainly get any zook that little bit further.
Post Posted: Tue May 11, 2010 9:08 pm
Post Posted: Wed May 12, 2010 12:19 am
mmm creepies!!!!
Post Posted: Wed May 12, 2010 11:40 am
Maybe some of these on 24's instead? http://www.coopertires.com.au/index.php ... tyre_id=9#
Post Posted: Wed May 12, 2010 11:45 am
32x9R16 TSL Super Swamper mate.
Post Posted: Wed May 12, 2010 11:46 am
24s???? bugger that
go 26s :P
-indebt 4x4 club-
Post Posted: Wed May 12, 2010 11:48 am
so they would be the SAM-40's...
how do you find them being bias & do they bag alright being under a light weight zook?
how are they wearing?
Post Posted: Wed May 12, 2010 11:55 am
These will be the ones on the realistic list though in a 215/85R16 with a decent (light) set of alloys. www.coopertires.com.au...yre_04.jpg
Post Posted: Wed May 12, 2010 11:57 am
links dead for me mate
-indebt 4x4 club-
Post Posted: Wed May 12, 2010 12:16 pm
They bag really well seeing as i only run 4psi in them :D
Wearing fine as they are only run offroad and they grip in every situation i have thrown at them, even rock.
Post Posted: Wed May 12, 2010 12:19 pm
beadlocked???
DAMN IT I SHOULD HAVE GRABED THOSE CHEAP SWAMPERS OFF EBAY
Users browsing this forum: No registered users and 290 guests
