It is currently Mon Sep 21, 2026 5:30 am
Vehicle: 75 Cruiser
Post Posted: Sun Feb 22, 2009 11:51 pm
I had a problem with my fuel gauge reading empty when the tank was full, and the gauge wouldn't start working properly until i had about half a tank of fuel. This is a pretty common thing with Sierras. Chris [nissvit] on this forum said it was easy to fix so i pulled the tank out and took some photos along the way.
1. Remove the tank
2. Remove the fuel leve float thing
3. Bend open the tags and remove the case
There isn't supposed to be a gap here where the pink arrow is pointing to. These surfaces should be in contact.
The usual problem is that these surfaces get a thin film built up over the years which stops the contact of the surfaces. We cleaned these surfaces highlighted by the pink lines.
Stick it all back together and off ya go....simple peaceout
Post Posted: Mon Feb 23, 2009 12:43 am
Yep works :)
Post Posted: Mon Feb 23, 2009 1:52 am
hmm, might have to try that when i get the motivation to pull the tank out..
Post Posted: Mon Feb 01, 2010 8:56 pm
proves my theory e for enough
HOLD MY BEER,AND WATCH THIS
Post Posted: Tue Feb 02, 2010 11:54 pm
Thanks Steve, gave me the motivation to pull Spooky's tank and fix the sender while waiting for my engine rebuild. The photos were great and made the job so much easier. Undoing that main fuel line is a bitch unless you drop the tank slightly to gain access to it. The problem was the wiper arm was only touching the bottom half of the coil. A little bending here and there and Bob's your uncle, it's working again. :D
Post Posted: Wed Feb 03, 2010 12:18 am
My zook does the same I will have to pull the tank and have ago thanks steve btw you should put this up as a tech article
 Profile YIM
Vehicle: 93 Sierra
Post Posted: Sun May 09, 2010 12:29 pm
Hmmm. Could we pretty please have some pics back Steve?
Vehicle: 93 Sierra
Post Posted: Sat Jul 31, 2010 10:01 am
Thanks Steve - works a treat :)
Post Posted: Sun Aug 01, 2010 9:46 am
Thanks for bringing this back up the top. Made me do my stocka today. Worked a treat. On ya Steve. :-)
Post Posted: Sun Aug 01, 2010 11:21 am
I might have to do this to the vit, mine read about 3/4 when ive filled it up.
Vehicle: 93 Sierra
Post Posted: Sun Aug 01, 2010 11:55 am
Actually now that I've used over half a tank of fuel I can see that it's still pretty inaccurate, but a stack better than it was before! I still had about 8 ohms resistance with the float at 'full' level after cleaning ... I suspect this is a bit high still as I don't get all the way to the top of the gauge when full.
Still ... I'm used to filling off the trip meter :P
Post Posted: Sun Apr 10, 2011 6:20 am
I know this is an old one here, and I am grave digin' but I had a thought
Can ya run an earth to the sender (and just the send) for testing, and run the arm up and down manually. Hav soone chck the gauge. iffen it don't read empty when it is empty, maybe bend the float up, so the at=r can drop more?
same goes with reading full too soon. Just bend the arm up a littl and it will show less fuel.
tell me iffen' I am missing something but it should correct for a bad/inaccurate gauge too. as long as the gauge is consistent.
Hope it helps in the future..
--Sky
Vehicle: Daisy
Post Posted: Sun Apr 10, 2011 10:07 am
--Sky
Yeh, you can run an earth to the top of the sender, that's the main problem I had with mine (however I also had it out and cleaned it with contact cleaner) and you can test it while it's out of the tank. I checked the guage while it was down, then cable tied it in the full position and checked again. Works a charm now!
EDIT: You shouldn't need to bend the arm, check that the full range of your float is the full range of your guage and you're set, don't put it back in until you get it working properly :p
Vehicle: 87 SJ50 Sierra
Post Posted: Fri Feb 03, 2012 9:16 am
Thank's! Worked for me
Vehicle: 1988 Suzuki Sierra Hardtop
Post Posted: Mon Nov 05, 2018 12:13 pm
Any chance we could get these photos again?
Cheers,
Matt
Vehicle: 91 Tin Top
Post Posted: Tue Nov 06, 2018 9:51 am
Cheers,
Matt
Here's one I took when testing the gauge on mine.
You can also test if the gauge is working by grounding the sender wire.
It should read full when earthed.
I just ran a piece of wire from the tank long enough that I could stand at the door and see the gauge when I earthed it on the the door catch (any non painted surface will do).
I also ran a new dedicated earth wire (the blue one) from the tank to the body, just for good measure.
Users browsing this forum: No registered users and 142 guests
