It is currently Sat Oct 17, 2026 6:29 am
Vehicle: 94 swb Vitara
Post Posted: Fri May 14, 2010 2:55 am
just curious my dash is already out of my 94 would the 96 or whenever the v6 vitara came out dash fit into it? has anybody tried it? i put a roll cage in out of one into my 94 so i assume the dash dimensions are also the same.. though i have been known to be wrong from time to time :wink:
Post Posted: Fri May 14, 2010 3:08 am
i can't see why it wouldn't "fit" you'd want to suss out all the mounting points, loom & plugs + the vent controls etc & grab everything you need.
Post Posted: Fri May 14, 2010 3:24 am
yeh thats what i was thinking dimension wise, i use to have a hq with a hx dash in it i assume same deal, il head down to the wreckers and suss those vent controls and mounts out everything else would seemingly fall into place though is the instrumentation cluster the same i think its only the dome top as opposed to the flat top dash cover that is the difference?
Post Posted: Fri May 14, 2010 3:44 am
If the v6 dash is the same as mine and Gus's it will fit Saam done it on that green one he rebuilt for his mate....
Post Posted: Fri May 14, 2010 3:50 am
SV420 dashboard with no airbags which is the same as the SV620 dashboard.
Post Posted: Fri May 14, 2010 4:20 am
Yep and thats the same as in mine so yes it will fit :wink:
Post Posted: Fri May 14, 2010 4:42 am
reckon the looms different, the speedo wont fit and the switches will all be in the wrong spot
also think youll need to swap the heater over too
Post Posted: Fri May 14, 2010 4:49 am
I didnt think about them bits :oops:
I didn't say it would work i just said it will fit :wink:
When Saam done his he swaped everything over......
Post Posted: Fri May 14, 2010 5:18 am
ha ha thanks for the input guys il look into it further
Post Posted: Fri May 14, 2010 5:21 am
while im at it has anyone changed the door trims over?
Post Posted: Fri May 14, 2010 5:40 am
I have been told lwb and swb doors are different
Post Posted: Fri May 14, 2010 5:48 am
if both swb's?
Post Posted: Fri May 14, 2010 6:11 am
afaik there are only two different types jlx with p/w and jx none p/w
All the jx ones i have seen look the same right through out all the year models jlx im not too sure on
Users browsing this forum: Google [Bot] and 232 guests
