It is currently Sat Oct 24, 2026 4:47 pm
Post Posted: Sat May 15, 2010 12:17 am
Hey,
Ive come across a cheap (~$500) complete swift sedan manual 1.6 (i think tbi) What is involved in putting this motor into my sierra that is different from a normal 1.6 swap? Dizzy? Radiator hoses?
Thanks
Post Posted: Sat May 15, 2010 12:32 am
I was told the heads on them are not much good and known to crack
Post Posted: Sun May 16, 2010 1:58 am
Just ignore this comment. Its based on nothing tangable. Image
Birko,
It will be almost the same as doing a baleno swap, which there are quite a few threads on this website, detailing the required mods to fit an east west motor in N/S orientation.
Just try the search function.
As for the motor, I have used this motor before with no issues what so ever.
Go for it.
Peter
Post Posted: Sun May 16, 2010 3:26 am
Birko,
Go for it.
Peter
if that's the case I will use the setup i found I was just stating info I was told and I didn't buy the setup because of that info
thanks for clearing it up Pete :cheers:
Post Posted: Sun May 16, 2010 6:19 am
I'm based on nothing tangable. Image
Post Posted: Sun May 16, 2010 6:23 am
Birko,
Go for it.
Peter
and how many swift motors have you had to deal with on a daily basis?
they are a different casting to a baleno head or a vitara head. the casting had issues and 99.9% of the heads will crack. if it has been repaired by a reputable shop it will be fine, but its the luck of the draw and if the head is cracked or will crack they dump a bucket load of water in the sump.....bye bye crank....
if you buy the motor get the head completely checked out.
i'm offering this info on the countless conversions an repairs i had to do (not just experience with maybe one motor). i ended up offering a conversion kit to run a vit mpfi head with swift tbi....problem solved.
Post Posted: Sun May 16, 2010 6:53 am
Birko,
Go for it.
Peter
4 or 5. No probs yet. Guess that .1% is all on MY doorstep :roll:
Users browsing this forum: Google [Bot] and 279 guests
